I have put in new rechargeable batteries and still did not solve the problem.
SOURCE: Philips CD455 Cordless Phone trio set
You can get a PDF of the manual online.
Go to www.philips.com/support, enter your model number, select the right one from the list.
A page comes up with info about your model. Choose User Manuals.
I copied this link, but I don't know if it will work: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=CORDLESS_PHONES_CA&sct=DIGITAL_CORDLESS_PHONES_SU&grp=PHONES_GR&session=20080119144138_89.83.85.31&ctn=CD4453S/05&mid=Link_UserManuals&hlt=Link_UserManuals
SOURCE: Telstra F4100 Dect Cordless Phone Problem:
i subscribe to bt for caller id but has suddenly stopped working and just comes up call. do i need to get new batteries?
SOURCE: my phones (philips cd445) will not hold a charge
You might have what is called "memory'. If you continue to replace the phone on it's charger after each call the battery will "think" it's empty, giving you s short charge time. Next time you replace the batteries (rechargeable) FULLY charge them then leave the phone off the charger until you go to bed at night.
SOURCE: Iphone hangs during standby mode.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
