Question about Sony Cameras
My sony cybershot dsc t99 camera turn off after showing the cybershot logo
    Master:
  • 364 Answers
Weak battery.
Posted on Jul 09, 2016
6ya staff
SOURCE:
Anonymous
SOURCE: driver for sony cybershot DSC-W55
hello,
i need a driver for sony dsc-w55
Posted on Sep 14, 2008
Rammsteins
Toms Safranovs
  • 300 Answers
SOURCE: Stuck power button on my Sony cybershot dsc-s600
Hi!
Yes, power buttons do break on these cameras. Contact your local Sony service center and see how much will it cost to replace the top panel. If they ask too much, feel free to contact me at [email protected]
I work in a Sony service center.
Tom
Posted on Jul 28, 2009
Anonymous
SOURCE: sony Cybershot DSC-W150,screen reads turn power on and off again
You may not believe this and I hope you haven't spent a lot of money fixing your problem. I read that some people had a different error message coming up on their Sony Cybershot DSC-W150's and in order to fix it, they literally banged the lens against their knee while the lens was out and it re-focused and the error message disappeared. I tried this while my camera was doing exactly what you described above AND IT WORKED!!!!!!!!!!!!!!!!!!!!
After 2 or 3 firm blows, my LCD screen came up and focused. I can't believe it myself, but I was just desperate enough to try it and VOILA!
Good luck!!
Posted on Aug 30, 2009
AdiIngel
Adi Ingel
  • 87 Answers
SOURCE: Cyber-shot DSC-T70 Digital Camera: My Sony Cybershot dsct70 touch screen vibrates whe...
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on May 26, 2010
sandracontri
SOURCE: Format Error in Sony Cybershot
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Posted on Jul 07, 2010
Sony Cybershot Dsc-505
Are you sure it is your charger and not the battery? (Batteries)
You could buy a new Sony charger, but there are lots of universal camera battery chargers, that won't cost as much and you can use it for every battery from every camera. Pick the right one and you have a charger for years to come, whatever your new camera will be and how big or small the batteries are.
Jan 05, 2014 | Sony Cybershot DSC-F505, Cybershot...
Sony cybershot dsc-t77 fell in fresh water
Hello :
Please read this solution here . Please give the solution a try . It has worked with alot of mini devices just like your Camera .
good luck .
please don't forget to rate !
Apr 07, 2010 | Sony Cybershot DSC-T77 Digital Camera
SONY CYBERSHOT DSC T2 keep shaking?
This is a known issue with the DSC-T20 Cameras.
Check this link for more information and get it serviced to resolve the issue.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT20&news_id=269
NOTE: Confirm the model # of the Camera whether it is DSC-T20 or DSC-T2.
Good Luck!!!!!!!!!!
Oct 08, 2009 | Sony Cybershot DSC-T200 Digital Camera
Same Problem!!!!!
CCD FAILURE
Call Sony for FREE REPAIRS
they know abt it
pls rate me well
Aug 10, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Hello pleasehelp me.. i have sony cybershot
Hi!
It's probably stuck focus. Contact your local Sony service center, but if they ask too much, you can contact me at [email protected] and I will give you a good price.
I work in Sony service center.
Tom
Jul 16, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
My sony cybershot dsc-h3
Symptom shows your DSC-H3 has problem in Lens Mechanism and you need to replace complete lens.
If you want to replace it by yourself, Its part number is as follows...
A-1359-213-A LENS BLOCK ASSY
It is available in Parts Store on $150
Or contact nearest Sony Service Center for replacement.
Oct 12, 2008 | Sony Cybershot DSC-H3 Digital Camera
Sony cybershot dsc-n1 took 6000 pics and stopped working Screen went white before died with lense extended no sign of power next cybershot DSC-N2 took 15,000 pic and died just refuses to turn on. no power...
no non of sony cameras come with any life pan
ya they are telling something baout life cycle
but i have cybershot with 29000 pic and my friend is having about 20000 so if your cameras is in warrenty period then go to sony service station they will fix it
or if you r out of warranty period then go for repairing your camera probebly changing CCD of your camera will fix this problem
Mar 26, 2008 | Cameras
Cameras Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
suresh Kulkarni
suresh Kulkarni
Are you a Sony Camera Expert? Answer questions, earn points and help others
