Question about Epson WorkForce WF-7620 Wireless Color All-in-One Inkjet Printer
How do I fix error code 0x97 on Epson printer
Each time I attempt to print, my printer fails and displays Error Code 0x97 on its screen. As advised, I turned the printer off and on but I am still unable to print and each time receive the same error code. How do I clear this code?
Posted by Barbara Coke on
  • Ronald Urbaniak
    Ronald Urbaniak Aug 31, 2016
    Epson WF-4630 Error Code 0x97: After a year of working perfectly, I started getting a partial print, followed by Error Code 0x97, but only when printing from my iMac. No problem printing from Windows 10. I reinstalled the printer driver in OS X but no help. On a hunch, I simply unplugged the printer, plugged it back in and now it's working again. Not sure it's a permanent fix, but good in a pinch.
  • Smith William
    Smith William May 01, 2019
    Follow this link to get rid out of your problemhttps://www.printererrorsupport.com/blog...
yustina wilson
    Novelist:
    Habit-Forming:
  • 118 Answers
How To Fix Epson Printer Error Code 0x97 Epson Printer users need to know about How To Fix Epson Printer Error Code 0x97 so just make a call on Epson Printer Support 1-802-618-6092 anytime and experts will help you 24*7 to fix issue. Issues like Epson Printer not working and many more, can be solved under the guidance of experts so just make a call on Epson customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7.
http://www.allsupportno.com/fix-epson-printer-error-code-0x97
Posted on May 22, 2020
Jay Plesset
  • Epson Master
  • 2,942 Answers
0x97 is a scanner circuit board error. You can reset your printer by unplugging it from the wall for a few minutes, and then trying again. Unplug is not the same as "turn off". Other than that, service center is your only answer.
Posted on Aug 31, 2016
5 Related Answers
Inky
Inky Fingers
  • 705 Answers
SOURCE: epson stylus photo 895 error code
1Eb means no black ink, 1Ec means no colour. Change the cartridges and you should be good. you will need Epson cart numbers: T007 Black T008 Colour
Posted on Sep 28, 2007
Anonymous
  • 41 Answers
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
Posted on Jan 22, 2009
Anonymous
  • 41 Answers
Hello , follow this link and try to find solution in this link : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
Anonymous
SOURCE: Epson RX580
Grease the metal bar with plenty of lithium grease on both sides of the print head (manually move it back and forth over the grease.  That should fix it.
Posted on Jan 13, 2010
Anonymous
  • 677 Answers
SOURCE: Epson Stylus printer is connected, but will not
Found this on the Web. If you find helpful, pls rate me.
Here is the link for all the discussions regarding this error.
http://discussions.apple.com/thread.jspa?threadID=2199441
Welcome to Apple Discussions
Go to: Apple > System Preferences > Print & Fax > Print and reselect your printer in the Default printer: box near the bottom of the panel. Then next in the same Print & Fax preference panel, select Open Print Queue: and Delete all the Jobs in the Status box and try printing something again.
reply
have no idea exactly what that error means, but now I suspect that when you "Trashed the EPSON folder in HD\Library\Printers\Epson" you trashed an important part of the OS X and not the installed Epson software.
If you have a backup Time Machine, a backup clone or that file is still in the trash you need to restore it "HD/Library/Printers/Epson/InkjetPrinters2 or whatever" back to the correct location, run Repair Permissions and hope that fixes it. If not then backup all your files, because it seems like you may have to completely reinstall the OS X....
Good Luck.....
Posted on Mar 05, 2010
Epson wf-3640 getting error 0x97
There's no doubt that Epson printers are one of the best printers that you can find in the market these days. But best doesn't mean perfect. There's a high chance that you will be a victim of error code 0x97 if you are using Epson printer especially for a long time. The error code 0x97 can occur at any time without any warnings or signs. Usually this error presents itself on the printer with an indicator to turn the printer off and on again. Usually this error code will show up during the printing process and your printer will stop printing afterwards. So for as long as this error keeps showing up, you won't be able to use your printer.
Honestly you can replace this printer for less than a hundred bucks
Mar 22, 2018 | Epson Office Equipment & Supplies
What is an Ox97 or 0x97 error code on an Epson WF-3640 printer?
Error Code 0x97 in Epson WF- 4630 means there is decrement in efficiency of printer. The printer may be not printing the pages as it used to print earlier. You don't need to worry anymore. You can follow either of the Solution to resolve the Error.
Solution 1:
Step 1: Download "0x97 Fix Patch:
Step 2: Click "Scan" button.
Step 3: Click :Fix" button to repair the Printer.
Solution 2:Step 1: Restart the computer. Login as an administrator user.
Step 2: Click "Start" button> "All Programs"> "Accessories"> "Tools"> "System restore".
Step 3 : Now click "Restore my machine to an earlier date"> "Next".
Step 4: Select most recent system restore date within the "tap a restoration date" Listing and click "Next".
Step 5: Click "Next" on the verification window.
Step 6: Restart your PC is required after the completion of restoration process.
Now, try to work with your printer again.
Call Epson Printer Support Team 1-800-213-8289 if the Error is not resolved or you are having any other kind of issues.
Visit: Epson Printer Support Phone Number 1 800 213 8289 Tech Support
Jul 06, 2017 | Epson Office Equipment & Supplies
Epson workforce wf-4630 printer what dose the error code 0x97 indicate.
Check our video out on a very similar model. Had error code that your printer is having:
Jan 12, 2017 | Epson WorkForce WF-4630 Wireless Color...
Error code HC11111
Anna, without knowing what your device might be, we're not going to be much help....
Oct 29, 2015 | Office Equipment & Supplies
How to resolve error 0x97 on Epson WF-3640?
First, here's a copy of the manual:
https://files.support.epson.com/docid/cpd4/cpd40083.pdf
Second, attempt the following which I copied this answer from another post concerning the same error code:
"The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times." (Post by Anjazmoro Wicaksono)
If that does not work, are you able to open the printer and look for anything that may be blocking proper function?
Jul 03, 2015 | Epson WorkForce WF-3640 Wireless Color...
On an Epson WF-4630, what does error code 0x97 mean and how do I correct it?
I am on my second printer with the error. Epson explained it is a motherboard failure. The error is not caused by a PC or the software on it. Instead, this is a printer hardware failure.
After exchanging the printer, the replacement printer has now dies from the same error. The problem starts as blurry printing and progresses to the full hardware failure. Once the Hardware fails and you get the error code, there is nothing an end user can do. The motherboard needs to be replaced.
My printers were working fine up until I swapped out the factory cartridges that shipped with the printer. In both of my cases, there were no issues or symptoms until I started using the Epson XL cartridges. As soon as I installed those, the symptoms started to show. Within a couple of months after swapping in the XL cartridges, the motherboard dies.
Options:
1) Call Epson and complain, make them log the details even if it is out of warranty. This helps establish the pattern and knowledge of the issue.
2) Swap printer if under warranty. They may want a credit card to charge in case they do not receive the bad printer back. Just resend it in the box the replacement came in. Epson supplies shipping labels and covers the shipping costs.
Mar 27, 2015 | Epson WorkForce WF-4630 Wireless Color...
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Error E000733-0001
There is a poor contact between the DC control PCB and main controol PCB .
to clear this error press * 28 * and select copier &select function & select clear and press OK
((*)means additional function button on display).
Jul 29, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Epson WorkForce WF-7620 Wireless Color All-in-One Inkjet Printer Logo
3,063 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
