Question about Haier Refrigerators
My haier fridge freezer is making a loud buzzing noise. Any ideas what it is and can it be repaired
Posted by John Bates on
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Loud buzzing noise
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
Mar 01, 2014 | Maytag MFD2560HES Bottom Freezer French...
Hi I've just come back from holiday to find that my fridge freezer is not working. The freezer has defrosted and the fridge is not cold. It started to make loud noises on and off before I went away. Any...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 08, 2010 | Neff Refrigerators
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Oct 31, 2007 | Refrigerators
Refrigerators Logo
770 people viewed this question
Top Haier Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
