Question about Casio EXILIM EX-Z1000 Digital Camera
Camera Turns off
When the camera is turned on, its cuts off after 3 secs, the battery has a full charge, so I don't understand what's the problem.
Posted by Bugzzy on
  • Anonymous Jan 17, 2008
    My camara turn off and i send to repair it and they told my that the camara need to replace the zoom assemble . The cost of repair is 155 pluss tax
Anonymous
  • 58 Answers
There is a setting in the "Set UP" menu somewhere, where you can set how long that the camera will stay on until shutting off to save power.
Good luck.
Posted on Dec 06, 2007
Recharged battery and camera will not turn on. Checked battery showing 4.3 v indicating full charge. what now
remove battery from camera
wait a few sec.
plug it in
pres RESET on camera (paper clip hole)
power on
Mar 02, 2011 | Canon PowerShot A3100 IS Digital Camera
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 20, 2011 | Samsung WB550 Digital Camera
It turns on then off almost instantly, the batery is fully charged.
i hope it will gives you success.
Jan 18, 2011 | Kodak Cameras
Everytime I turn on my camera, it just turns back off...even with new batteries. I don't know what the problem is, Help Please! Thanks!
Jan 17, 2011 | FUJIFILM FinePix S1600 Digital Camera
Camera shuts down when 'zoom lens' is used.
Jun 10, 2010 | Kodak EasyShare C913 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camara shuts off as soon as it turns on. Lens
I believed that you are using the battery came from the box the KLIC-7004 which is very good. Now since the battery indicates its charge, first thing you need to do is to removed the battery and Memory card, Now wipe the 3 metal contacts of your battery then reinsert only the battery in your camera then Turn It On. If the camera shuts off try to used 5V AC adaptor to Turn On the camera, If this failed to turn On using the AC adaptor It means the camera needs of service call Kodak Tech support toll free 1 800 421 6699 ext 12
Nov 09, 2009 | Kodak EasyShare M1033 Digital Camera
My camera turns on but turns off right away, and i know its charged.
When I turn the Camera on - - - - It quickly turns itself off. I have new batteries that have a full charge on them.
Aug 04, 2008 | Canon PowerShot S3 IS Digital Camera
I purchased an olympus fe-330 8.0 megapixel camera about a month ago and worked ok until about a week ago when it just wont turn on. i have tried to charge the battery but the red light only comes on for...
when the red light is off, it means it is fully charged.
May be you are puting it wrong side in the camera. check the arrow to put in the camera
check with the service centre.
Jul 10, 2008 | Olympus Cameras
Camera will not charge the battery
Well. Ive got the same problem only ive gone thru 3 batteries trying to figure out what the problem is. When i plug it in to charge the light turns red , then within 5 sec's turns green. It stays green but never charges the battery. After 24 hours, its still a dead battery. Im just assuming since its 5 years old that the internal charger is shot. Looking for a new camera at this time.
Aug 20, 2006 | Gateway DC-T50 Digital Camera
Casio EXILIM EX-Z1000 Digital Camera Logo
32 people viewed this question
Top Casio Cameras Experts
Ekse
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a Casio Camera Expert? Answer questions, earn points and help others
