Question about Pioneer Audio Players & Recorders
Pioneer cx4000 home stereo no rear speakers/subwoofers very low sound. only surround sound works normally
Posted by Jeremy Dugan on
    Top Expert:
  • Pioneer Master
  • 76,823 Answers
Either the sub woofer speaker or the sub woofer amplifier section circuit has the fault. Contact any service technician to make diagnosis the faulty section. If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jul 04, 2016
5 Related Answers
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
Anonymous
  • 54 Answers
SOURCE: 4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Posted on Dec 09, 2007
Anonymous
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
Anonymous
  • 1199 Answers
SOURCE: speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Posted on Dec 28, 2008
Anonymous
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Posted on Jan 07, 2009
    Center speaker problem on pioneer vsx 40 .I hooked up the center speaker and I can’t get sound from it
    Most problems are menu settings, because surround modes can be complex and confusing. Verify what surround input type you are using. FM tuner will not play center spkr unless put into a simulate or expand stereo mode. Do other surround speakers work other than normal L/R stereo mode? You can try redoing your auto surround setup (MCACC) or going to the manual speaker setup and verifying speaker is turned on in menu system. Rechech you listening mode setups at Pages 33,38,39 in your manual. Try another speaker and wiring on center output. Try Different surround inputs, some manufactuers have had problems with their DTS and HDMI boards. Otherwise take to repair.
    Why is it intermittently losing channels...front speakers and or rear surround?
    How to troubleshoot low sound or no audio from the rear ...
    https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
    Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
    Why Are My Speakers Producing Static? - Electronic House ...
    www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
    Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
    How to Check if your Speakers are Wired Correctly ' Richard ...
    www.richardfarrar.com > Podcasting
    Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
    Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
    www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
    Sep 20, 2008 - 30 posts - ‎24 authors
    The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
    Jan 23, 2014
    Sony Receiver going in to Protect Mode
    Jan 12, 2012
    The Official Sony STR-DH820 Thread
    Aug 29, 2011
    Denon AVR-1910 - No more sound.
    Feb 15, 2011
    More results from www.avsforum.com
    2helpful
    2answers
    My sony dav dz270 home theatre has no sound through centre and rear speaker
    You must have changed the listing mode to stereo.In that mode only the left / right & subwoofer will work. Press the surround button and change it to any other mode .
    2helpful
    Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
    In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
    Stereo-Front Left and Right speakers including subwoofer
    Dolby Digital or PLII Movie-these are the bost options for your surround sound
    Direct-All speakers connected get full range signal
    Good Luck
    I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
    The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
    I moved into a house with pioneer home system &media receiver is flashing...i did notice 2 of 3 speakers aren't giving any sound..what is wrong
    you can try a few things on the simple side:
    1- change sound simulation to other than stereo, maybe to cinema or surround.
    2- if your receiver has a audio calibration program built in, than maybe the microphone was unplugged during calibration thereby leaving the receiver in a calibration mode where only the speakers that completed the calibration function are active.
    2helpful
    Pioneer vsx-519 no sound from center and surround
    Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
    You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
    If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
    Center and rear speakers not working
    In regard to the rear speakers, my system is an LG and the rear speakers will only work if the format that i'm watching (TV, DVD) is in Dolby surround sound 5.1. Normal tv will not give you surround sound unless it says otherwise, usually it will flash up on the screen at the start of the show. So test the unit with something that you know is in 5.1
    2helpful
    2answers
    Just bought a Philips home theatre system HTS3544 low sound?
    You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
    I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
    ST
    My Onkyo TX SV 535 Surround Sound wont work
    when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
    and you select surround sound in listening mode.
    Top Pioneer Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Morne Olivier
    Morne Olivier
    Steve Sweetleaf
    Steve Sweetleaf
    Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
