Question about Acer Extensa Computers & Internet
How to lock the task bar when it does not showing on screen
The taskbar is not showing or the start bottom
Posted by judy waller on
How to get taskbar back
Hi, if your on a Windows system press the Windows key to open the Start menu, in the Search option at the bottom type taskbar, this should show you Taskbar and Start Menu option.
Select the Taskbar and Start Menu option
Check the AutoHide option is not ticked, and check the taskbar location is set to Bottom, if you make any changes click the Apply then ok.
Aug 28, 2014 | Computers & Internet
My compaq presario wont let me see my tabs, it will not show if i bring thre mouse to the bottome
By tabs, I assume you mean "taskbar". On your keyboard is the windows flag....between Ctrl & Alt. Hitting that should make the taskbar pop up.
You can then change your settings to keep the taskbar always visible.
If you taskbar is not longer on the bottom (on the side), click & drag it to the bottom.
Oct 11, 2013 | Compaq Computers & Internet
Move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
I have an Asus 1000HE netbook. The battery icon just disappeared from my taskbar at the bottom of my screen - how do I get it back?
You can try the two steps below:
1. Right click on your desktop
2. Select properties
3. Select "Screen Saver" tab
4. Click on the "Power" button
5. Select "Advanced" tab
6. Check the "Always show icon..." box then apply
or...
1. You may have to right click on your Taskbar
2. Select "Properties"
3. Click on the "Customize" button in the Notification area
4. Click on the power item in the list
5. Select the option you want from the drop down
Your feedback is greatly appreciated. Thank you for using FIXYA.
Apr 26, 2011 | ASUS Eee PC 1000HE Netbook
Sound icon doesn't show up on bottom toolbar
Right click on any blank part of your taskbar, then left click on Properties, a windows titled "Taskbar and Start Menu Properties" will open : click on the "Notification Area" tab, then, under Syatem Icons, put a check mark on "Volume", then click on "Apply", click on "OK" and the "Taskbar and Start Menu Properties" window will close and you will have the Volume (Sound) icon in the Notification Area of the Taskbar.
Sep 19, 2010 | Computers & Internet
On my Vista desktop, the start/taskbar shows up on the right side when it used to be along the bottom of the screen. why did it move and how can i get it back to the bottom?
First, right-click the taskbar. If "Lock the Taskbar" has a check mark next to it, the taskbar is locked. You can unlock it by clicking "Lock the Taskbar" again. Then, click an empty space on the taskbar, hold and drag the taskbar to one of the four edges of the desktop. When the taskbar is where you want it, release the mouse button.
Mar 08, 2010 | HP Pavilion dv9000z Notebook
My taskbar is not showing after u start the computer
When you say "after u start the computer" you mean before you log in? The taskbar never shows up until you're logged in, so that's the way it's supposed to work.
If you've logged in and you still can't see the taskbar, it's possible that you've configured the taskbar to "auto-hide." To see if that's what's happening, move the mouse all the way to the bottom of the screen, and the taskbar should pop into view. Unless you've moved the taskbar to the top or side - check by moving the mouse all the way to each edge of the screen until you see the taskbar.
Once you see the taskbar, you can right-click either on the "Start" button or on the clock at the opposite end of the taskbar, and select "Properties" from the menu to turn off auto-hide (if you want to - some people like it once they're used to it). If you want to turn it off, pick the "Taskbar" tab on the Properties dialog, and uncheck the "auto-hide the taskbar" checkbox. Then click OK, and the taskbar should stay visible.
Hope this helps.
Oct 06, 2009 | Microsoft Windows XP Home Edition
In vista: taskbar does not show icons of opened files
it might be your taskbar is on auto hide try this
Show or hide the taskbar gl_icon_tip.png Applies to all editions of Windows Vista.
The taskbar is usually located at the bottom of your screen. It looks like this:
getopencontent.aspx?assetid=984f8561-57a1-4b9c-9f22-f0d8dddec294&documentset=en-us&renderkey=xml Taskbar
You can hide the taskbar to create more space. If you don't see the taskbar anywhere on the screen, it might be hidden.
Hide allShow allHide all gl_arrow_down_static.gif To show the taskbar
• If the taskbar is hidden, point to where you last saw it to show it again. If you can't remember where you last saw it, try pointing to the bottom of the screen first, and then to the side or top of the screen, if necessary. You might need to move the pointer almost off the screen to show the taskbar.
gl_arrow_down_static.gif To hide the taskbar
1. Open Taskbar and Start Menu Properties by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
2. Clear the Lock the taskbar check box.
3. Select the Auto-hide the taskbar check box.
The taskbar is hidden from view. You can see it again by pointing to the place where you last saw it.
gl_arrow_down_static.gif To turn off auto-hide
2. Clear the Auto-hide the taskbar check box.
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
Windows XP taskbar has "relocated itself"
Right-click the taskbar and ensure it's not locked..
Then just click on the taskbar and drag it to the bottom of the screen..
But i didn't understood the iconzied windows thing.. omg
PS: Please rate this solution
Mar 11, 2009 | IBM Lenovo ThinkPad T60
Computers & Internet Logo
37 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
