Question about American Tourister Splash 21" Expandable Suitcase - Solar Rose
I have AT suitcase. Opened as per above instructions. Suitcase is open. Forgotten combination lock no. How to set the new lock combination
Forgotten combi lock no. Now opened seeing your instructions. How to reset new combination lock 3 digits
Posted by Subramaniyan... on
Our suitcase is locked, and we forgot the combination. how can we reset the combination for our TSA approved luggage?
resetting the combination is only practical if the suitcase is open as the reset tab is located inside where it cannot be tampered with when locked.
if it is a set of dials lock a locksmith could help you.
regards,
Mar 25, 2018 | Luggage & Travel
I have forgotten combination tomy suitcase and it is locked how can i get it unlocked
Start at 000 and go up one number at a time until it opens or reachest 999.. it will take some time. .. good luck.
Dec 01, 2014 | Samsonite Silhouette 11 Hardside Spinner
How do I make my lock lock again
Does the red indicator show ?
Is it a padlock or suitcase lock ?
It sounds like the combo has been changed.
Feb 19, 2014 | Locks & Locksmithing
Roncato suitcase forgotten my combination and cant open the suitcase
I have a Roncato hard shell with a 3 digit combination lock under the handle. I set the combination YEARS ago, had a young child play "horsey" on it, and turned all the numbers! The suitcase was locked and I had forgotten the combination. I followed the instructions in answer 2 above and it worked! I didn't have to add or subtract 5. I used a small sewing needle and a strong flashlight - the indentations were easy to see.
Feb 11, 2013 | Samsonite Photography
Please tell me how to set teh lock code for my samsonite silhouette 11 HS....no instructions were included! help!!
Sure... here're the instructions - open the suitcase, then open the zipper in the modesty pouch (it is mounted on the backside of the suitcase, along its entire length), and then from in there, take out the plastic packet. In the plastic packet are labels, warranty information, AND voila - the instructions to set the combination lock... :-)
I would tell you here too:
1. Open the suitcase
2. Look at the inside back of the lock - you would see a red color tab, and two markings - A
Aug 30, 2010 | Samsonite Silhouette 11 SoftSide 22"...
Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Nov 08, 2009 | Samsonite Tripod
I do not know the combination of my samsonite hard case suitcase
I tried working through the series of possible numbers and at the same time gently pressing the lower part of the lock to see if it would open. After a while I used a claw hammer which I gently inserted the claw beneath the lower portion of the lock and again gently prised it and at first go the lock opened and no damage done that I can see. I have not reset the lock yet.
Oct 16, 2009 | Samsonite Tripod
I have a VIP suitcase with three digit combination lock. Thouh I have not changed the code, it is not opening. It seems to have stuck. I have tried to open it even with a few earlier combinations or my...
I just opened mine. I also knew the the password and the suitcase wasn't unlocking. If you are all sure that u know the password. Then put some oil in the lock. wait for 1 hour... This will help. If it doesn't work then.. Put the lock code and push the clips manually with a pait or scissors or a small blunt knife.. Don't worry the lock is just stuck. After all it's a vip and not samsonite
Mar 21, 2009 | Baby Gear
Presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Jan 14, 2009 | Extensis Suitcase X1
Suitcase number locked combination forgotten
f'lite Samsonite combination lost and stuck locked:
I removed the lock unfastening the 2 torx screws from the case.
Next I removed the pin that holds the RED tab thingy in place and the spring ( all this does is pushthe assembly to the right when a number is moved..... Take a picture of this before you dissassemble it. push it allthe way through..if you have fat fingers you are screwed. Anyway, remove the red thingy, and then carefully lift the remaining plate out taking note of the orientation.
First of all: the solution is aligning the cogs to 0-0-0 like from the factory. This is easy to do. when you remove the plate above , carefully do so without launching the dials and the spring into space....no matter.
Look at the bottom of the plate and notice there is a notch that will correspond to the cogs still in place on the lock assembly that should still be in place.
The cogs sit on a spring that sit on the backside of the dials with the numbers you can see when locking the suitcase.
Here is the meat:
1. with your finger or something turn the cogs until the black dot aligns outmost.
2 align the cogs so that notch will correspond to the orientation on the plate you just looked at. (that's it)!
Carefully replace the plate with finger pressure and actuate the latch-it should be unlocked and at the 0-0-0 position. If not repeat 1 and 2.
Push the pin through again, through the red thingy and the spring. BAMMM! you just saved your self a zillion dollars...still having trouble...mail this to me and for $15. I fix it for yaz....
May 13, 2008 | Samsonite Tripod
American Tourister Splash 21" Expandable Suitcase - Solar Rose Logo
250 people viewed this question
Top American Tourister Luggage & Travel Experts
ADMIN Canada
ADMIN Canada
ray gallant
Tom Chichester
Are you an American Tourister Luggage and Travel Expert? Answer questions, earn points and help others
