Washing Machines Logo
Question about Electrolux Washing Machines
Electrolux Ultra One Z8820. The lights do not lid up when we place the power chord.
We checked and we have power until the flat wire inside. When we unplug the flat wire and put it back into the CN1 space the lights lid up for a second but stop immediately. We cannot figure out why cause nothing seems burned or broken. Thanks for your help
Posted by Ingrid Van Vaek on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: lid locked no power
use a screwdriver in the crevice beneath the lid. Approx 4 inches from each side you will see a 1" silver piece of metal, push the tab towards the back of the machine. Once you get one side loose place something such as a screwdriver to keep it unlatched until you get the other side loose. The top should come open. And there is also a service book inside your washing machine, I fixed mine myself. Look at my other postings. Good luck!!
Posted on Nov 22, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Maytag washer just died on me
the reset button is usually built into a switch that resets automatically when the lid is opened and tub recentered, you rmodel doesnt show one, but there is a mention of a 10 amp fuse( if so equipped) on the wire diagram. shows it connected right to the L1 wire(line 1) trace the linecord in and see if it gets you to a fuse. possible a bad lid switch and/ or plunger for the switch, not making contact when door is closed
Posted on Mar 18, 2008
Anonymous
  • 5911 Answers
SOURCE: kenmore ultra fabric care I washer; 80 series- lid switch needs replaced
This is a very easy problem that you can repair yourself. The following link explains in detail how to replace a lid switch such as yours:
http://www.fixya.com/support/r385198-replacing_lid_switch
A replacement switch can be purchased on line at any of the following sources:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
All three sites offer great service and have competitive pricing. So, shop all three for the best price. Just use your COMPLETE model number (usually located under the washer lid along the tub rim) to begin your search criteria. If you do not wish to order on line, use the part number provided by the Sears website and go to your nearest appliance parts retailer. Yes, this a part that they should carry in their inventory.
If you have questions, or need further assistance, please let me know. I hope this helps you.
Posted on Jan 16, 2009
Anonymous
  • 1430 Answers
SOURCE: I have a sears kenmore 80 series 110.24852300. The
There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available
Posted on Apr 07, 2010
Anonymous
  • 2341 Answers
SOURCE: Hello Everyone, I have a Roper
that sounds like you have done all you can and i appriciate a well written question stating exactly what you have already done(some times questions here is "it dont work") so then back to your washer. There are 2 more possiblities
1) the motor capiciator is bad and not giving the motor a bump in power to start it. To check that,its black and round and going to be on inside right side of back panel.To check it use a meter set to HIGH ohms rating.place one meter lead on each of the 2 terminals (each terminal may have 2 wires but only 2 two terminals) and the needle should swing up and drop back if cap. is good and the needle will stay at or near zero if cap. bad. If using digital meter the numbers will constiantly be in motion jumping from 10 thousand to 200 back to 5 thou. and so forth if cap is good and again the display will stay the same and never change if capiciator is bad
If capiciator checks good the motor is going to be the problem
Good luck,i have i have been able to help you fix your washer,
Gene
Posted on Aug 18, 2011
My electrolux type EWF10842, on display find error EHO, what mean this error,and how to resset, thanks
The EHO (or EH0) error indicates a problem with the incoming power or an electrical problem inside the washer. Unplug the washer for a while to reset the error code. Next check your wiring and make sure that the outlet doesn't have a fault. If you live in an area with brown-outs or wires that touched during a storm, wait until the electricity is repaired. Then check if the power supply to the washer was damaged by the surge or changing power levels.
If these aren't responsible for the problem, you'll need to check the wiring for shielding damage, the wire harnesses and the rest of the washer. There is a parts diagram here: http://docplayer.net/60693214-Spare-parts-list-household-washing-machines-pnc-elc-brand-model-market-electrolux-ewf10842-th-washing-machines-front-loaded.html .
I hope this helps.
Problem with Germ Guardian Humidifier H2000B - Light turns red and the mist stops coming out after a few seconds of turning on the humidifier. There is plenty of water in the tank and the device is clean.
There are a few things to check that would cause the empty light to go on and the mist to stop.
Rinse the lid on the bottom of the blue tank. After you rinse it with warm water, dry it and then push the spring on the outside of the lid, it should move easily. Check the inside of the lid and make sure the rubber gasket is securely in place.
Remove the spray guide, and on the base of the humidifier to the side of the ultra sonic disk is a small white plastic pole with a washer-ring around it. This is the float, make sure it moves easily up and down the pole. Use white vinegar on a cloth or paper towel and wipe the pole down.
Reassemble the humidifier, use room temperature water in the tank, set to warm mist and let run for 30-40 minutes. Please make sure the humidifier is on a flat level surface, no carpeting or towel underneath.
1helpful
I have a bunn ultra 2 flat lid ice machine, manual failed to come with the machine. it needs cleaning, the 'clean due now' is always on the screen, followed the info on the side of it to clean and even let...
Can go to the Bunn website.Go to commercial section,then manual index and then specialty drinks.You can find :Illustrated parts,operating service,service,repair and programming.
10helpful
E90 ERROR ELECTROLUX 1087 WASHING MACHINE
Error 90 is a common fault code in domestics within the Electrolux, Zanussi, AEG range. It's a wiring fault /connection normally between the printed cicuit board and wires. switch off power, remove lid, pull off each connector on board checking for clip holding the connector in place, one at a time, look for arcing marks, rub pins gently with clean cloth, tensinsion up clips in connector(delicately) and refit. having done this, test again with a wet load on spin, then a wash programme. Before dispairing check the motor coonnections.
5helpful
3answers
Power head turns on and off as the unit is vacuuming
Probably not hose but more then likely is a problem within your wand. Try connecting your hose handle directly to your powerhead and see if you can get consisten power. I work in customer service for electrolux and more then likely it is in fact the wand
6helpful
How do i open canister for cord retract repair
There are four screws under the lid, and there are two additional screws under the face plate for the controls display. You'll need a thin, flat blade screw driver to "pop" the face plate off. The two additional screws that you are looking for are deeply recessed about the bracket-nozzle park.
E172FPb Flat Panel Color Monitor black screen problem
Your backlight inverter inside the monitor is out. If you are comfortable soldering you can repair it yourself. We have a step by step repair guide on our web site at: www.ccl-la.com/LCDrepair5.htm
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
WILL NOT RUN (KSM90WW)
theadore something is not connected right or something else got disconnected. there is no reset on these mixers. may i ask why you removed the back housing?
No Power
i'm having the same problem.
check the power supply chord that connects into the tv. I have to adjust a jiggle the chord until the red light on front panel comes on.
The power supply chord needs to be replaced.
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
