Question about Samsung PN60F5300 60 Inch 1080p Plasma
The TV was working good. Ever since I moved to different house, my TV started to not working anymore. I checked to see if it's the power cord, it wasn't it. I see that the red light at the bottom left blink a few times when I press the power button. It blinks and then pause a little bit and then blinks again which around 14 times blinking in total while no display. I replaced a new power supply did not do any good. Please any help is appreciated. Thank you!
It sounds like a bad circuit or outlet. Replacing the power supply will not fix it. Try measuring the voltage with TV on. Try it again with an electric iron, waffle iron or something like that plugged in. You should not sag by more then 3 or 4 volts. Be aware this may cause a wiring fault to fail and could cause a fire. If you get a large voltage sag turn the breaker off and get an electrician.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=inadaquate+power+on+circuit
Lights flickering Check household wiring
https://www.osha.gov/dte/grant_materials/fy08/sh-17792-08/electrical_english_r6.pdf
https://www.energex.com.au/__data/assets/pdf_file/0019/31447/esaa_common_power_supply_problems.pdf
Posted on Jul 02, 2016
Testimonial: "During the time I'm moving, there wasn't any storm or rain that cause the problem. Even now there isn't one by the time I'm posting this comment. I plugged my TV to the outlet, then I checked high voltage at "va-tp" and "vs-tp" on power supply, and I saw that the voltage at the highest decreasing at every blink the TV's LED light made. Therefore I want to know what I supposed to replace instead, since the power supply board wasn't it, and bad wiring can't be it either. I'm appreciated your reply."
Jun 25, 2016 | Televison & Video
Nov 09, 2013 | Samsung Televison & Video
Nov 12, 2012 | Televison & Video
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Dec 06, 2009 | Panasonic PT-56LCZ70 56" HDTV
Jun 26, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
May 18, 2009 | Sony KV-36FV26 TV
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Jan 28, 2009 | Televison & Video
Aug 06, 2007 | Sony KV-32FS13 TV
246 people viewed this question
