Question about AT&T El52300 Cordless Phone
Had a att el52300 base that went bad so bought another one it seems to be working ok. all head sets have out of Range or no Power at base.Tried to clear with answer given but nothing worked Need help
  • 372 Answers
Try the following:
1/ Make sure the power cord is securely plugged in at the base and that it's powered on ie: light is on and working etc..
2/ Reset the telephone base. Unplug the electrical power. Wait for
approximately 15 seconds, then plug it back in. Allow up to one minute for the cordless handset and telephone base to reset.
3/ Place the cordless handset in the telephone base for one minute to allow the cordless handset and base to synchronize.
Manual available here:
at&t el52300 manual
-Charles
Posted on Jul 02, 2016
5 Suggested Answers
Anonymous
SOURCE: Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Posted on Feb 19, 2007
Anonymous
SOURCE: Handset for my Olympia OL5870 is searching of base
hi ther candice wanta a uniden.
Posted on Feb 02, 2008
Anonymous
  • 7 Answers
SOURCE: Phone says OUT OF RANGE while on the base and won't work.
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
[email protected]
Posted on May 07, 2009
taran_2005
taran_2005
  • 10515 Answers
SOURCE: KEEPS SAYING NO LINK TO BASE - RECONNECT MAIN
ry this.
Registering a handset to a base unit
1 Base unit:
Press and hold {LOCATOR} for 4 seconds until the registration tone
sounds.
  • If all registered handsets start ringing, press the same button to stop. Then repeat this step.
  • The next step should be completed within 90 seconds.
2 Handset:
Press {OK}, then wait until a long beep sounds.
Note:
  • While registering, "Base registering" is displayed on all
registered handsets.
If the problem does not resolve, check that the AC cord is seated fully at the base of the unit and that the handset is fully charged.Use a different fuse for the phone to eliminate blown fuse issue which could be quite common.
If the problem persists, you need to send the phone for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 19, 2010
okorsal
  • 6 Answers
SOURCE: Panasonic TG5240 Handsets reset when I answer.
Were you able to Solve this one? if so, how?
Posted on Sep 27, 2010
Can a base for the AT&T EL 52300 be replaced and where would I find one?
Try Amazon or eBay, otherwise you will have to by a new one complete with the hand held.
Oct 30, 2015 | VTECH-ATT At&t El52300 Cordless Phone -...
I have hooked up my phones but all I get on the hand sets is no pwr at base and out of range, how can I fix this, I have already tried disconnecting and reconnecting
Is the base unit being powered up? Is the adapter that plugs into it working and supplying power to the base? If not nada will work and you will get the out of range indication on remote handsets.
Sep 26, 2015 | Vtech ATT CS6629-3 CS6629-3 DECT6.0 3...
At&T EL52300--one phone reads 'out of range-move closer to base.' I did--it doesn't help. Battery OK---What do I do?
It appears that the one handset has become orphaned and
must be de-registered and then re-registered.
1. To de-register the orphaned handset from the old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Oct 17, 2014 | AT&T El52300 Cordless Phone
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
Handset can not connect to base unit ATT E-2126
AT&T 2.4 cordlessE2126 handset will not reset to base
Apr 01, 2009 | AT&T E2126 2.4 GHz Cordless Phone
D51A PD IS DISPLAYED ON MY ATT E2562 HANDSET. ANY
My E2562 handset 1 would not detect base and displayed D51A PD whenever I tried to manually register it. This fixed it:
1. Remove battery from handset.
2. Unplug base and unplug phone connection(s). Wait 30 seconds.
3. Plug in base.
4. Plug in phone connection(s) to base.
5. Put battery back in handset. Handset 1 should then auto register with base.
Mar 15, 2009 | AT&T 2230 Cordless Phone
ATT 2wire 2701 HG-DSL lite on, but bad connection
If you have a 2wire HG2701 it experiences problems. You will need a new modem or a new router. I have one but it has the same problems. I went to FRYS Electronics and bought an speedstream modem. WORKS PERFECTLY
Feb 19, 2008 | 2wire 2700HG-B Router (2700HGB)
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
PROBLEMS with phone
Had the same issue. I have two units each with a handset, and one handset went to "out of range" status and stayed that way even after recharging. I tried to register it with that base and no luck. I then tried to register it with the other base and it worked. Then I tried to "swap" the handsets and no luck - it seems that the registration process on the one unit is toast so now I can only use the handsets with one of my two base units.
Oct 22, 2007 | Motorola Mobility MD7091 Cordless Phone
Out of range
I have a Radio Shack 2.4ghz cordless phone system and sometimes the handsets will show "Out of range".
My Solution that works for me.
Unplug the power cord and telephone line to the base for about 30 seconds. This seems to reset the base. Then plug everything back and you should be ok.
ET Sherman
Oct 07, 2007 | Panasonic KX-T7730 Corded Phone
AT&T El52300 Cordless Phone Logo
240 people viewed this question
Top AT&T Lands Phones Experts
Ekse
Marvin
Marvin
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
