Question about Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le
My RT A7210-1 unit stopped working. Noting happens when i turn it on No laser, no turning, nothing. Yes I changed the batteries
Does not work
Posted by Mike Yowhan on
1 Related Answer
Anonymous
  • 27 Answers
SOURCE: green light turns on momentarily, then nothing from unit
make sure batteries are tight in unit ,making good connection there are many internal things that could be wrong no rotation could be bad drive motor broken belt bad pcb robotoolz now owned by bosch who owns cst-berger discontinued robotoolz lasers there is a guy who will give free estimate on repair A.P. Service & supplies 610-944 8030
Posted on May 29, 2010
Headset turns green when charged but dose nothing eles
Probably your headset has some electronc falure. If it is not "disposable" you should take it to repair.
2answers
The laser will not light up. i've replaced the batteries
First, be sure to clean the battery connection points with an electrical contact cleaner and be sure that the batteries are new, not just different. If that does not work, try placing the instrument in a freezer for at least 30 minutes. This worked with my 5 point Stanley Fat Max. The freezer will cause some condensation to form on the inside of the instrument, but why it makes the diode work is a mystery, at least to me.
1helpful
Turn signals stopped working now no power
I concur this is a power supply fault of some sort, insure your battery connections are maintained, meaning clean and good of contact, obtain a voltmeter and test the voltage at the battery contacts it should be about 12.5 or higher, turn the key on and try to start, noting the voltage, if it drops below 11 volts, there's your fault if not a poor ground from the battery and the frame of your vehicle may be faulty but boosting your vehicle from another sports battery fault
1helpful
Need robolaser instructions; can not get it to turn on. it has new batteries.I really don't know anything about this laser. It was my Dad's he has passed away.
Did u open the front and turn on the remote to activate the laser ? the model i have ( 8years old )this is what it takes to get the laser work.
1helpful
My ps3 dosent read any discs
Hi my name is Juan an ps3 expert and this is what your problem is your bluray laser has stopped reading disk ,dvd bluray movies and games some lasers they still play regular dvds but not games some lasers play nothing and this is your case but don panic it can be fix you fix it your self or have someone fix it for you another laser will cost you around 65-75 depending on what model you have there is 2 different types of laser I can help you figure out which laser you have in the back of the unit there is a white label with the serial # and after the serial # is the model # it start with CECH--01can you please tell me what are the other two missing numbers between the H AND 01 look on your label and let me know this way I can tell you which laser you need to buy or if you want I do fix ps3 I do sell ps3's and parts on ebay I am a trusted power seller my Id is flacooo1 you can let me know here or on ebay which model # you have thanks and good luck
My 098 ninja won't click
perhaps you damaged the starter button or pinched a wire somewhere? check all wiring and connections, switches, buttons. if your bike a fuse block, check all appropriate fuses. if all these things are working properly, break out a multi-meter and check for continuity thru all wires associated with the ignition, fuse block, battery, and if all else fails, check out the starter, it may have been damaged somehow(excessive heat, liquids such as oil water brake fluid, or possibly metal shavings?) i dunno. but before you try everything i mentioned, listen to what the man above my post (FTjoe) has said. hope you get it back on the road bud. ride safe!
I have a mitsubishi electric air system. It just stopped working for no reason. All units are not working. The remote work fine yet when you press the button nothing happens. This is all of the house. ...
Hi Lisa,
First change the batteries in the remote. Is this a central system or separate units. It sounds like central which would have sequencers and fan relay that would keep it from coming on. mitsubishi uses pc boards for everything and they fail often. Unless you about elec. circuits then you will need an a/c contractor to troubleshoot the system. But first try the batteries if you haven't already.
8helpful
Won't advance slides
IF IT JUST DOESN'T WORK... (But the laser pointer is still working when in 'presentation' mode) You need to 'Sync' the presenter and the reciever... as follows: Turn the presenter on, and turn it over so you're looking at the back of it. See the button in the middle? Press that button, and the button on the USB reciever stick, simultaneously, while holding the two of them quite close together. Problem should be solved. If you turn it on and the display isn't working, or if the laser pointer doesn't work when in 'presentation' mode, you need to change the batteries. I thought I had a dud unit until I found out about the 'Sync' function!!! Definitely on the 'need to add to documentation' list!
Robotoolz RT-7210-1G Robolaser, Self-Leveling, Remote-Controlled, Laser Le Logo
Top Robotoolz Measuring Tools & Sensors Experts
ADMIN Canada
ADMIN Canada
ray gallant
 Mikey
Mikey
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
