0xc18a0101
Follow the below steps on the front panel of the All-in-One printer:
A.
- Press and Hold the “Print Photos” & “Red Eye Removal” buttons.
Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
Display says "enter special key combo"
Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal” .
If "support COxxFN0723BR" appears with "uiaux" message, perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status.
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8.
Press and release the “CANCEL” button as many times as necessary, so
that, either the “Welcome to Photosmart Express” screen appears, or,
the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT
THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10.
Wait 30 seconds for the power to get discharged and then plug the power
cable into the wall outlet first and then into the back of the printer
11.
Turn the unit on. The printer may display message “USE POWER BUTTON TO
SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12.
If the printer has already initialized, then go to the next step. If
not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”.
Allow this process to complete and do not interrupt. Once the
initialization process is complete, the printer will print out a
Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
