Universal AC Remote Control For CARRIER, GREE, CHIGO, ELECTROLUX,FUJITSU, GOLDSTAR, HAIER, HITACHI,HYUNDAI, LG, MCQUAY, MIDEA, MITSUBISHI, PANASONIC, PHILCO, SAMSUNG, SANYO, SHARP, TADIRAN, TOSHIBA, TRANE, WHIRLPOOL, UNI-AIR, YORK Logo
S
Sayed bahram Posted on Jun 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you reset E1 error code ? - Universal AC Remote Control For CARRIER, GREE, CHIGO, ELECTROLUX,FUJITSU, GOLDSTAR, HAIER, HITACHI,HYUNDAI, LG, MCQUAY, MIDEA, MITSUBISHI, PANASONIC, PHILCO, SAMSUNG, SANYO, SHARP, TADIRAN, TOSHIBA, TRANE, WHIRLPOOL, UNI-AIR, YORK
John Mabry
Level 2:
Sergeant:
  • Expert 273 Answers
  • Posted on Jul 03, 2016
John Mabry
Expert
Level 2:
Sergeant:
Answers
273
Questions
Helped
99797
Points
514
Change the batteries and see if there's a diff
E1 error code on a cz220 comfort zone model heater what does it mean
The E1 error code on a Comfort Zone CZ220 heater indicates a problem with the high-temperature limit switch. This switch is a safety feature that shuts off the heater if it overheats.
To clear the error code, you can try resetting the heater by unplugging it from the power outlet and waiting for at least 30 seconds before plugging it back in. If the error code persists, it may indicate a more serious issue with the heater that requires professional repair.
10helpful
3answers
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
2answers
Error E1 for washing machine
AK Techno service is the best service center for repairing and service for all types and brands of washing machines.
For more visit our website. http://aktechnoservice.com/samsung-washing-machine-service-center-in-hyderabad
samsung washing machine service center in hyderabad...-bo0djorvxqfflml1tozu5o0f-5-0.jpg
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 • Dishwashers
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
I have a fitness Edge 491 Recumbent bike that the display window reads E1 . the resistance is hard and I am unable to reset. when I press start stop for 2 seconds it all looks like it will reset but then...
The bike is no longer sold and the company went bankrupt in 2014, so neither support nor parts are available from the company. Try the results of this Google search regarding the E1 error code:
fitness quest edge 491 e1 error Google Search
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Nov 25, 2017 • Cycling
2answers
Sharp ARM207
try typing the error code into a search engine.
Pioneer error codes
E1 Error is an electrical failure. Check all Circuit breakers and insure that voltage is correct. Could be a simple wiring problem.
It may also be possible the circuit board is damaged. Check for a reset button on the wall plug if there is one, try reseting it.
My bremshey treadline control treadmill error e1 accurs need help
Is it possible to disable the e1 error code. Trying to repurpose motor.
4helpful
2answers
SHARP AR 275 PROBLEM E1 15 ERROR AFTER SOLVING THE U2 40 PROMLEM
Porfavor ayudenme necesito su ayuda urgentemente. este problema ya lleva 2 semanas asi y no me permite ni scanear ni imprimir ni nada.
Top Universal AC Remote Control Heating & Cooling Experts
Paul Carew
john h
Are you an Universal AC Remote Control Heating and Cooling Expert? Answer questions, earn points and help others
