Colibri C-Series Scepter CB-LTR014314 Logo
Question about Colibri C-Series Scepter CB-LTR014314
My pencil torch wont light or ignite.
It was made in taiwan and bought it at a thrift store. It's brand new in the box
Posted by Lorna Allen on
  • 5 more comments
  • Brad Brown Jun 30, 2016
    Hi Lorna Allen, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? don't see the original question
  • ADMIN Andrew
    ADMIN Andrew Jun 30, 2016
    New poster Brad :>)
  • Lorna Allen
    Lorna Allen Jun 30, 2016
  • Lorna Allen
    Sorry guys
  • ADMIN Andrew
    No, problem. I have changed the category to something which is a bit closer than 'motorcycles'.
  • Lorna Allen
    Thank you very much
  • Lorna Allen
    The kind of torch I have doesnt have an igniter, you simply turn the tip and it's supposed to be releasing gas but it's not. I took it apart and all the seals are in the correct order and I cleared out the valve opening but still no go.
Is the back of my generva watch 5573 s a pop off or screw off?
Best to take it to a jeweller as battery replacement if not knowing how can damage the movement. Otherwise a screw back has little notches on the side of the back and a press back is smooth. You will need a back opening knife to open.
Nov 27, 2017 • The Watches
Battery replacement for G Shock AWG-M100
Sounds like someone has replaced the rechargeable cell with a regular silver oxide of the same dimensions. Normally this doesn't work as the rechargeable cells have a part of the connector welded to them and normal cells don't. If you can source the rechargeable cell they are relatively easy to fit you just have to make sure the connector on the cell goes into the righ tplace on the watch.
Brand new watch does not run
the problem is the battery of the watch. it has to be replaced by new one, it is new but it probably sat for a long time in selling shelves that when the time you purchased it, it is out of battery charged. you can bring it to the watch retailer store from where you bought it and you can ask for the warranty of your watch. i hope i had been helped you.
51-30 black face. brand new from store and watch wont run. do i need a battery or is the watch supposed to be wound? what is the smaller lower dial for?
bring it back to the store where you had purchsed it. and ask for the warranty of the battery of the watch. the sub dial is for tide tracker whether it is low or high.
I lost my Dakota Torch REQ SOS with solid cover/shield. I am trying to find another. I have the charger for it.
Here's a link directly to the Dakota website for this particular brand of watch:
https://dakota.webfeatsecurity.com/watches.aspx?sr=t&Series=25
I looked briefly on E-bay and only saw one available auction for this type of watch, here's the link (it's shortened because E-bay links are huuuuge)
http://goo.gl/gpqq9
I bought the G by Guess watch G99005G1 and it won't start. It's brand new, never used out of the box. How do I get it to start?
The watch should be working when you take it out of the box, unless there is something stated in your owners manual. The battery is probably flat or there is an other issue, either way the watch should be returned for exchange.
Dec 31, 2010 • Watches
1helpful
I am looking for watches to buy at thrift stores and resell. Are there any certain brands or a certain mark I should look for?
No, there isn't any decent brands or makes. You will struggle to resell them and I doubt you will get any profit at all.
Oct 28, 2010 • Watches
2answers
I cant find where to buy a new watch band
Dear Friend,
                 U can Purchase a new branded watch at Fast track which is one of the best brand among the watch companies.If u need to buy am Indian Brand then u can take a choice of Titan
Regards,
Aysaam
Top Colibri Watches Experts
Marvin
Marvin
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Colibri Watch Expert? Answer questions, earn points and help others
