Question about Eaton Computers & Internet
Eaton nova avr 1250 freaks me out when voltage drops the ups automatically shows a red lights on nd turn off the green one i connected it troughs usb to check the ba3 its 100% charged
  • Anonymous Jun 29, 2016
    Sure i know buh it does the same thing if i disconnect it from mains or if light goes out even i tried disconnecting every thing from it please its still all the same issue
Tom Chichester
    Top Expert:
  • Eaton Master
  • 55,983 Answers
Your Eaton nova avr 1250 may be doing what it is supposed to do in the event of a voltage drop.
Posted on Jun 28, 2016
2 Related Answers
Anonymous
SOURCE: Mge nova avr 1250 problem
ups charged for 8 hrs .No alarms but on powerfail no output to connected device
Posted on Jun 20, 2009
Azrael SRL
  • 11800 Answers
SOURCE: Charging voltage is 27.5vdc, batt voltage 27vdc
Normal for a battery that is starting to show its age. Save for a replacement in the near future.
Posted on Jan 21, 2010
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Denon Amplifier AVR 2808
Could be a power related problem or you may have speakers connected that have an impedance less than recommended
May 18, 2013 | Audio Players & Recorders
Red power light blinking on my denon avr 1907, tried reset procedure, no speakers hooked up now and it still goes from green light to blinking red light and shuts off...Any clues?
This is a protection mode. The receiver protection circuit detects an internal problem like missing power supply voltage or blown channel and shuts down the receiver. You need to bring the unit to a repair facility.
Sep 26, 2011 | Denon AVR-1907 Receiver
DFI ns35-tc/tl Total power off requested. When pc is turned off,a red led light keeps shining, indicating motherboard is still powered. This is probably the reason that a USB Power Saving Center will not...
The red light is just a pilot light indicating that it is still
connected to the power line. To get it totally off, is to
unplug the unit from the outlet. If your PC is connected
to the AVR (Automatic Voltage Regulator), just turn the
power switch off at the AVR. Hope this help you.
Dec 09, 2009 | DFI NS35-TL Motherboard
Amp light is neither green or red
have u connectted the remote wire from head unit to turn amp on? have u got + and - the rite way round.hope this of use.
Mar 05, 2009 | Power Acoustik PS2-1250 Car Audio...
Hi i jus need box and speaker specs for the dual 2 ohm 10pw3
General Information Manufacturer: Eaton Corporation
Manufacturer Part Number: 103004248-5592
Manufacturer Website Address: www.eaton.com/EatonCom/Markets/NorthAmerica
Brand Name: Eaton
Product Series: PW3105
Product Model: PW3105 700
Product Name: Powerware PW3105 700VA Tower UPS
Product Type: Standby UPS
Technical Information Plug/Connector Type: NEMA 5-15P
Receptacles: 4 x NEMA 5-15R - Battery Backup System
Switching Time:
  • 6 ms
  • 6 ms
Dataline Protection: RJ-45 Internet
Power Description Load Capacity: 700VA/420W
Input Voltage: 110V AC
Input Voltage Range: 0V AC to 160V AC
Output Voltage: 115V AC
Frequency:
  • 50Hz
  • 60Hz
Management Overload Protection: Circuit Breaker
Interfaces/Ports Interfaces/Ports: 1 x USB
Battery Information Batteries: Maintenance Free Sealed Lead-acid
Backup/Run Time: 3 Minute 420W Full-load
Physical Characteristics Form Factor: Tower
Dimensions:
  • 4.4" Height x 11" Width x 7" Depth
Weight: 9.7 lb
Miscellaneous Certifications & Standards:
  • Safety: UL 1778 3rd Edtion/CSAC22.2 No107.3, Designed to meet UL497A
  • EMI: FCC Class B
  • Software Included: Powerware LanSafe Software
    Green Compliance: Yes
    Green Compliance Certificate/Authority: RoHS
    Jan 22, 2009 | Powerware PW3105 700 (103004248-5501)...
    Nov 15, 2008 | Computers & Internet
    Repair manual
    Problem solved! The main power thingy (the thing with the big red wire coming out of it) was all black and dusty. There was 'soot' all over the whole insides of the monitor. I concluded that this monitor should be laid to rest, and a new flat-screen monitor erected in its place.
    Nov 18, 2007 | ViewSonic G220f (Beige) 21" CRT Monitor
    Computers & Internet Logo
    699 people viewed this question
    Top Eaton Computers & Internet Experts
    Gruber Power...
    Gruber Power...
    jimixclay
    Tom Chichester
    Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
