Washing Machines Logo
Jen Beck Posted on Jun 27, 2016
Ge washer whre5550k2ww tub wont spin
Washer does everything, except spin. Tub spins freely by hand, but is locked up during washing and won't spin. Agitator works fine, fills, drains... everything except spin. Sears tried to sell me a new motor over chat.Is that it?
scott Levengood
Level 1:
Habit-Forming:
New Friend:
  • Contributor 10 Answers
  • Posted on Jun 27, 2016
scott Levengood
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
10
Questions
10
Helped
11480
Points
21
It may be the rotor position sensor. i used you tube tutorials. There are many washers that are the same, but different brand names. Matag, whirlpool, kenmore elite oasis, all the same and parts. I got lucky and a cleaning hack. It was to clean between the tob and thre shell. This is located up under where you cannot see, use a mirror and look wherr your detergent, fabric softer and bleach dispensers are. And i found a tutorial on diagnosting code that will do it for you. I think it was holding a cycle 5x for 5 seconds and it will tell you. Whats wrong, Good Luck
Testimonial: "Unfortunately that's not yhe prooblem, but thank you for the reply."
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
I have a GE washer which the agitator and tub do not spin. I can turn both freely by hand. The belt is in tact. During the cycle, the motor just osillates a minute amount in both the clock and counter...
it might be the safety switch under the door.
it is a switch that will not allow the spin cycle to spin unless the door is closed - like when you look in your washer while its spinning and as soon as you open the door the spinning stops until you shut the door again.
if its damaged it will not allow the spin cycle to work.
try look under the lid.
costs around $3.00 put in with a screw driver good luck
aloha
8helpful
2answers
I tried washing a rug - I believe it was too heavy and moved the washer around during the spin cycle. Now it is not spinning, it make the sound but it won't turn - I can move the tub around with my hand...
Hello- First unplug the washer. The out-of-balance switch may have gotten tripped. If you open the lid and look in the space between the tub and the top in the rear right corner you should see a plastic "arm" sticking down, reach you hand back there and move it back away from the tub. This lever actuates a switch in the control panel that will prevent it from spinning if there is pressure on it, it should be hanging freely away from the tub. Plug the machine back in and test it. If it doesn't work another thing that may be happening is the tub is not engaging on the transmission. With the tub empty reach inside the top perimeter of the tub and lift it up and let it down a few times, sometimes this will reset it and get it to spin. Lastly, i would check that the lid is locking when you put it into spin, the lid lock light should come on and you should not be able to lift the lid. If the lid is not locking you may need to have a F/P Tech out to replace the lid lock. You can test the spin by setting the machine to Permanent Press and advancing the cycle to spin. It will take a few minutes to start spinning usually. Let me know what you discover, good luck. Best regards.
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
1helpful
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
4helpful
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
1helpful
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Helpp
If you have removed the drive belt from the rear pulley and the inner spin basket does not spin freely, you either have a drum bearing seized up on you, or something binding between the spin basket (stainless steel tub) and the outer tub shell. First, you need to reach inside the wash tub with the washer empty. Place the palm of your hand at the 12 o'clock position and push straight up. There shouldn't be any play in the spin basket. If you can feel the basket wobble up and down, you have either a bearing problem, or a spin basket support (spider arm) broken on the back of the spin basket. If there is no play at all, you probably have something caught. Small articles of clothing can sometimes get pulled between the tubs and usually ends up around the support shaft in the rear. This will obstruct the basket from spinning freely and could eventually cause damage to the drive motor, spin basket and/or tub bearings. You can use the instructions for replacing a rear tub bearing that I have posted under my Tip and Tricks for instructions on how to disassemble and inspect the tub. The bearing may not be bad, but you still need to check to see if anything is binding the spin basket against the tub shell and inspect the spin basket supports. Unfortunately, you have to disassemble the washer to be able to inspect any of these items I mention. I hope this helps you.
Wont spin
low voltage can cause this if you can use a meter do a voltage drop test plug the meter under where you have the washer plugged in read the meter then start the washer and and see how much the volts drop if falls 12 volts have an outlet promblem let me know i will hang with you
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
