Question about Sharp MX-2700N Color Copier
A LOUD NOISE WHEN I TURN ON MY COPIER SHARP MX-2300N AND IT CAN COPY OR PRINT
COMING OUT BLANK BOTH IN COPY AND PRINTING AND ALSO MAKING NOISE WHEN TURN ON
Posted by patience jerome on
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
Posted on Jul 13, 2010
Anonymous
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
Anonymous
SOURCE: MX-2300N Sharp Copier will not print
Do you have setup accounts on the copier?
Posted on Apr 02, 2009
unkl foddy
  • 120 Answers
SOURCE: hello i have copier machine sharp mx-450u,with
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Posted on Jul 09, 2009
SOURCE: how to print back to back pages on sharp Mx-2300N
Back to back mean duplex print .If your copier has a duplex cassette you can use duplex print before configure it see your user guide and follow this function.
Posted on Dec 16, 2009
Printing jobs are coming out blank
Does this happen if you make a copy? Or print any internal form meter count sheet demo page etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 14, 2014 | Konica Minolta bizhub C250 All-In-One...
Nothing at all printing or copying, just blank pages
hi and welcome to fixya
Your printers ink Carthage is empty ! making noise of printing and blank pages is because of the empty cartage bring a new cartage and then printer will print the pages
Dec 07, 2012 | Epson Stylus Photo RX520/RX530
Creased paper
If that happened to me I'd try printing a dozen - 100, if needed - pure blank white pages in an effort to clear any other problem without wasting toner.
Nov 05, 2017 | Samsung Office Equipment & Supplies
Canon PIXMA MX300 Office All-In-One Printer and Fax MX 300 printing blank sheets
Do you have ink in the cartridges? Just because the computer says there is ink does not mean there really is ink.
Try making a copy and see if it copies. That will tell you if you have ink. Just go to the canon all in one and place something on it to copy and press copy from the controls panel on the printer.
May 31, 2012 | Office Equipment & Supplies
My HP laserjet 1200 is making a terrible noise when printing - do you have to oil the rollers?
No Please don't oil any part of the printer, oiling may damage the complete printer first check if the nopise is coming from rear, Top, Front or side.
If noise is coming from Top than possibly top outbin roller are making noise.
If side tham may be toner cartridge or cartridge motor is making.
If noise is coming from rear than either fuser or the gear which rotates the fuser are making noise.
If noise is coming from from than Tray 2 pickup assembly or faulty tray is making noise possibly faulty registration assembly can also mak noise none of the part should be oiled only the faulty part should be replaced.
May 11, 2009 | HP LaserJet 1200 Printer
My HP Officejet 6310 makes a squealing noise when printing, like the roller needs oiling-any suggestions on what to do?
turn off the printer..connect the printer to wall outlet..and try to make a copy..if its still the same..perform these steps..
1)unplug the power chord from the back of the printer..
2)press and hold OK and CANCEL button together..
3)while pressing these two buttons plug in the power chord to the back of the printer..
4)after you plug in the power chord do not release those two buttons..
5)keep pressing those two buttons till the screen goes blank..
6)once the screen is blank release the buttons and turn on the printer..
7)wait for the printer to get initialize..
8)once the initialization is complete..try to make a copy..if the printer is still making noises..then machine should be replaced..
let me know after you perform these steps
Mar 10, 2009 | HP Officejet 6310 All-In-One InkJet...
Not printing
try to press and hold the copy and cancel button at the same time. It should take up a pice of paper and spit it out blank. then try to print again. if problems persist call the 1 800 235 6325 kodak support hotline
Jul 25, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Grinding Noise and no printing
grinding is NOT cool...i'd say that you have a mechanism issue with this printer. How long have you know this printer?
Mar 03, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer is not working.
There are several things in the front that could be making that noise.The transfer roller,paper guide/top ublique roller and front obligue roller which is on the left side front. It is hard to say. I guess the printer is printing OK. If not what is the printer doing? Do you get any paper jams? Printing light? Can you rub the print off the paper? Any labels stuck? Please answer questions so I can help you. My guess is a roller problem. Which one is hard to say since I can't hear the printer myself.
Jan 13, 2008 | HP LaserJet 4L Printer
LOUD thumping noise when printing
Fuser/ upper heat roller/film or lower pressure roller has lost it's coating, nees new fuser assembly (hot bit at back) about $150 plus labour
Oct 12, 2007 | HP LaserJet 1300 Printer
Sharp MX-2700N Color Copier Logo
120 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
