Question about Ovens
I have an F53 ERROR on my oven ARISTON OS89IX.also..the blower remain turn on...never stop until I stop electrical power from outlet. when I connect again...problem appear again...how can I fix it..?
Posted by FREECOCO on
  • FREECOCO Jun 27, 2016
    ariston OS89IX...is the model
  • ray gallant Jun 27, 2016
    I find no code F53 for an artisan. I would contact a repair tech locally
5 Related Answers
Powerman
Charlie Popeck
  • 68 Answers
SOURCE: kenmore electric oven 337098
While I can't promise results, it sounds similar to a problem I have helped over 1100 other solve. Please go to the following link: http://fp1.centurytel.net/Powerman/Dreaded F7 Problem.pdf Let me know if it works for you. You can email me at [email protected]
Posted on Aug 20, 2007
BADBOYJAY
Jason Harris
  • 274 Answers
SOURCE: blower remains on when oven is turned off
yes it is normal i have one and it has been doing that sine i brought it i took it a part and there is nout wrong with it so yer its fine
Posted on Jan 05, 2008
David Coomer
  • 1073 Answers
SOURCE: electric power cord
good safety move to turn off gas
Posted on Apr 12, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
Posted on Dec 31, 2008
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Power failure and error codes
You could send that board to Bruce at fixyourboard.com and he would fix it for around 135 bucks and warranty it. I have a guide to late model oven repair manuals and more here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 03, 2011
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
How to stop lights flashing on the control panel
Unplug the oven from the outlet or turn off the circuit breaker that controls power to the oven.
Wait about 5 or 10 minutes- so that any remaining stored capacitor voltage has been fully drained.
Restore power to the oven- if you get an alpha-numeric error/fault code or the lights on the oven's control panel blink, refer to your owner's manual for troubleshooting and/or interpreting the fault codes or flashing lights; or you can try contacting your local appliance repair shop for assistance in interpreting the fault errors or to schedule a repair service call.
Sometimes you can Google the error codes for info, help, and repair solutions...
You can also try the oven manufacturer's website to resolve your problem- they may have a troubleshooting/solutions link or phone number to get live tech support...hope this helps.
Mar 08, 2015 | Ovens
What means er 07 at Ariston electric oven FD 87.1 E and how can I fix the problem?
THE E USUALY STANDS FOR ERROR THE O7 IS THE ERROR WHICH COULD BE IN THE OVEN,BROILER, OR BURNERS, OR EVEN A TIMER. LOOK UP ON LINE TYPE IN FD87.1 ELECTRIC OVEN MANUAL TO SEE IF A MANUAL IS AVAILABLE THAT YOU MAY BE ABLE TO FIND THE PROBLEM.
Jan 31, 2015 | Ariston Technologies Ovens
Ariston wall oven error code f53 f03
I managed to resolve that problem. When you have BOTH F53 and F03 error codes, it's not a sensor fault (although F03 is the big cavity sensor and F53 is the top one)... it's a faulty capacitor trouble. On the main board there are 4 electrolytic capacitors, just replace all of them and you're ok again. It's quite simple and very cheap. :-)
Nov 26, 2013 | Ariston Technologies Ovens
Hotpoint Ariston FK 89EL.20 X/HA Electric Oven
Same error. No fix find yet. Only push on/off button 3 seconds.
Aug 11, 2012 | Hotpoint Ariston DY46 Electric Oven
Hi my Ariston oven shows in the display error 07. I have an ariston oven FZ 87.1 (IX)
problem je v nedostatku vzduchu pri ventilatori,treba viac priestoru pre ruru
problem is the lack of air when fan, need more space for tube
Jun 29, 2011 | Ariston Technologies Ariston FO98P...
Oven door wont open code f53 thermador how can i get it open food is in it
Hello,.
Welcome to FixYa.
The "F53" error code on your Thermador "C" series ovens indicates a upper door lock fault, makes sense since that is the issue you described.
Whether there is actually a fault with the lock remains to be seen. Here is what I`d suggest you try...
Locate the service panel for your oven ( should be an isolated 40amp breaker ) and turn it off for a few moments and turn it back on.
This will initiate the start-up sequence which activates and checks the controls and lock assembly, hopefully resetting it to the "open" position and subsequently eliminating the error code.
Let me know how that works or if you require further assistance.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 29, 2010 | Thermador C302U Electric Double Oven
Ariston Oven power trip
Take off the back cover and check whether the terminals on the heating element are touching it. Normally caused by some earth leakage currents flowing from heating element to ground circuit.
Mar 01, 2009 | Ariston Technologies Ariston FO98P...
Control panel
generaly the only way to reset is by turning off the power to the oven at switch board for at least 30s. if this does not work check the back of the digital panal for any burn marks as it may have shorted when it fell back, also check any wiring connectors have not come off
Feb 18, 2008 | Ariston Technologies Ariston FO98P...
Blower remains on when oven is turned off
Jan 05, 2008 | DeLonghi DEBIG24 Gas Single Oven
Ovens Logo
449 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Oven Expert? Answer questions, earn points and help others
