Want decals asap
SOURCE: where do you plug the charger on little tykes H2?
The charger will plug directly into the battery, but it must be a specific little tikes battery charger because the connectors are slightly different than other battery connections.
The battery is usually located under the hood in front. I try to charge my batteries up at least 18 hours.
Hope this helps.
SOURCE: I need to remove the rear tires on a little tikes hummer h2,
I would take a pair of pliers and pull off the push nuts.
You have to replace the push nuts with new ones, but when you purchase the little tikes hummer wheels from http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
they provide the push nuts with the wheels
SOURCE: lost battery charger for little tyke junior quad
the junior quad is made for little tykes by a company called "fun creation" and the charger cannot be bought locally and must be ordered from them directly at: wwwfuncreation.net or calling 1-877-743-3899
SOURCE: where i can buy charger 12 volt for hummer H2 little tikes 884931120
Hi domgrenier...
You can contact this seller: Pyle PLMRA400 400 Watt 4 Channel Waterproof Marine Car Amplifier
probably he can provide charger too.
best of luck
