Check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Check that there is no recording set! Go to Menu and then Library settings and delete anything showing! This should clear the message showing again!
Testimonial: "I have aready checked that there is no recording set, in both timers and library. The message is still showing. Do I need to clear all the recordings that I have set and then reset them?"
