The wire should not be hot until the relay is triggered. The relay does not get triggered until the ignition key is turned on. It will run for 3-5 seconds or until the system pressure it at max.
SOURCE: 98 chevrolet silverado k2500 4x4 left rear brake light not workin
I have the full wiring harness for the exterior lights if you need it. Send me a email with a link to this posting and I will send you the diagram. [email protected]
SOURCE: how to connect a 4 wire trailer system to a 1994
Tail lights and brake lights are on the same wire.
Connect the wire from the brake light to the connector in the car to the tail lamp wire connector and you will be set to roll
SOURCE: wiring diagram for a 1978 dodge 440 engine in a Cobra class A motor home
I am sorry but we do not have any wiring diagrams. You can buy the factory chassis diagrams but not mnot what was added by the motor home builder. If you know what chassis the unit was guilt on you can look up a used manual here.
SOURCE: Wiring harness problem
I have the same problem, left trailer light comes on, stays on until I touch any door handle. It appears that the interior courtacy lights coming on, put the tail light out. There seems to be a relationship between the courtacy lights and the activation of this tail light. I tried a different trailer and had the same problem with either trailer.
Hi James Hall, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
