How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
