Before you spend a ton of money on garages to figure this out. Look online line for recalls And upgrades for you PCM. P0007, doesn't apply to a Durango. Most likely you PCM has died. Seen it to many times with different manufacturers. They load all the software into PCM's. The VIN numbers release what the car needs. When the main chip fails, it can give false codes. Most false codes I ignore, But hen the kill the engine, I replace the PCM.
Steve, P0007 is an issue with the engine control module not receiving correct signals from your fuel shutoff valve. Could be a bad wire/plug. Fuel shutoff valve is located at the fuel supply rail on engine. See more info on P0007 code. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
P0007 OBD II Trouble Code Fuel Shutoff Valve Control Circuit High
http://www.obd-codes.com/trouble_codes
P0007 Fuel shut off valve circuit high
The "Fuel Shutoff Valve "A" Control Circuit High" indicates the problem may lie in the electrical circuit in the fuel shutoff valve control.
SOURCE: 1999 dodge durango 5.9 cranks but wont start no
It is your computer. I had this recently as well. No Bus means no connection to the on board computer. There is a company in Florida that repairs these computers, so don't get suckered in by the dealership for 750-1000.
SOURCE: 1988 Chevy S10 Durango Pickup, Won't start will fire
sounds like ignition module inside of distributor cap under distributor rotor button.these do go bad and can easily be replaced.strong suspicion from your details that this is the culprit.
SOURCE: 1998 Dodge Durango Turns over but wont start
could be Fuel Injectors, are bad ?
all you need is # 1 Fuel Injector, to go out that will not get Fire, and Fuel Mixture to Spark Plug.
SOURCE: My 2002 dodge durango wont start ran fine
Does your durango have a security system? Sometimes it may require a keyed entry of the drivers door, but i doubt thats your problem. One thing Durango's are cleptic on is their ability to act all sorts of awkward on a low battery. Maybe a good idea to try a known good battery before we jump into anything further. Any CEL's btw?
