You first need to buy R60 airtime for the network you are using such as MTN, Vodacom, Cell C etc. That R60 will be the amount you need for (BIS) Blackberry Internet Service. You need BIS to enable BBM (Blackberry Messenger) to work. Once you have topped up your airtime with R60, you need to dial *141*11# which should bring up the option to activate BIS. Choose BIS and not any other option. BIS is usually option 1, but just make sure you select to activate BIS. Once BIS is activated then you can go onto BBM (Blackberry Messenger) and you should be able to send messages. You then have internet access as well. The great thing about the BIS is that it lasts for a month, without you needing to pay anything after the R60 to send as many messages as you like for free on BBM, plus you can use the internet on your phone as much as you like too! I am experiencing a problem getting BIS on my Blackberry Curve which I shall ask a question about on this site!! Good luck :)
Most of the options are not available in the automatic point-n-shoot modes. You need to switch to one of the advanced PSAM modes to gain access to these options.
If you're not too comfortable with the advanced modes, turn the mode dial to P. The Programmed Auto mode is just like the green Auto mode, except that you have the ability to override the camera and choose options like Picture Control.
Option setting within "Setup" menu (need access code of 2222) allows you to see advanced features not normally viewed after installation of fax machine is completed. Within these advanced features is a parameter to choose analog line setting of either tone or pulse.
Hello Sir,
To check your Airtime Balance on your Orange Sim, Dial *111# and then after press Send.
You will be then reported of your balance.
Thank you Sir, Have a nice day.
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
