SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
SOURCE: How can I get my Dish Network remote to control my surround sound
If there are no codes in the manual then you may have two options left for you. You may order a 20 or 21 remote from Dish after verifying it will work with your system with customer service or you may get an ALL IN ONE REMOTE. Thanks for using Fix Ya and let me know if you need further assistance.
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
Hope this helps!
SOURCE: dish remote code for Viore 32" HD LCD
Hi, my name is Cheri Torres and I am with DISH Network customer service. I came across your post and wanted to see if I could help. DISHNetwork remotes have a few different codes for each of our different models of remotes.You should be able to find your remote model number on the back at the top ofyour remote it's usually a two to three digit number with a decimal point. Iwill list here for you the best codes for the most common DISH remotes and alsothe instructions for addressing your remote to your TV. The only codes that I was able to find for the Viore TV were for the 5.3 IR remote and the codes are 563 and 500. If these codes do not work you can also try running a channel scan to find your particular code. I will also list here for you the instructions for running a power scan. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to post back here or email me at [email protected]. :)
Instructions for addressing remote to TV,
Instructions for running a power scan
