I think this is now a new part. There are no nuts, instead just a lip in the plastic that clips in when they put it together. So to remove it, one must break the plastic arm off, so that one can turn this until the lip is outside, and only then it can easily be removed - Peter
What Peter says works. Just done it. The outer arm and the inner arm needed to be snapped ie the inner arm will stop it rotating further counter clockwise even with the outer part of the lever arm snapped. I heated a knife to melt through the plastic to make the inner arm weak enough to snap. Then once it can rotate further counter clockwise, it can be lifted clean off to allow it's replacement.
If you're still facing such issues, or any other backyard's problems, I can share with you this link ( here: https://lawncarebase.com/ ), where lawn care experts explain how to maintain your backyard and make your lawn much better than it was before. They have dozens of pretty informative webpages, with awesome comparison of different lawn mowers.
Very interesting question
cant get at it from underneath for sure
you can buy the part
best guess is take off the engine hood and pull the whole top to bits till you get to the broken handle
Bosch ROTAK 34 Manuals
SOURCE: I need insruction BOOK for Bosch Rotak 344 GC LAWNMOWER
Here you go:http://www.bosch-pt.co.uk/boptocs2-uk/modules/oragetblob.dll/Rotak34_manual.pdf?db=ocsr55_s041&item=OCSHEIMWPDF.v$m$d$lobvalues.r55&id=90005,10446,20&filename=Rotak34_manual.pdf
Just copy and paste that into your browser it will take you straight to the pdf for it.
SOURCE: LAWNMOWER INSTRUCTIONS ROTAK 34/36
click that and it will take you straight to the pdf file for it
