Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Hi Pamela... Magic bullet base gears can be purchased from amazon (my recommendation). Enter this link Healthy Blend of Power Precision and Value and choose carefully which one fits (by shape, size, price etc). I hope this was helpful. enjoy
Check the fuse. Blowing a power supply does not happen. Blowing a fuse often does. If the power supply truly went out, it is too small in amperage. More information on the power supply may help.
If you are lucky, it may just be a blown fuse. You can try disassembing the base unit and checking for an open fuse inside on the circuit board. Please remember to disconnect the power supply and the phone line before disassembly.
Otherwise the circuits in the base unit were probably fried in the resulting power surge and are likely beyond economical repair.
However, the old handset(s) are probably still good. So if you do get a new replacement base unit of the same model, then you can probably salvage the old handsets and just program them for use with the new base.
If the base has no power, then it is either the power adapter or the base itself. Power adapter can be tested using a multimeter on Volts. Value must be within half volt from specifications. If the voltage from power adapter is correct, then the base is defective. In that case call the number on phone manual to get the part replaced, those parts are not repairable.
Your base has taken a strike to the processor and it is stuck trying to boot up. If you have cycled the power already and it stays stuck, it is not going to boot. Buying a replacement base (you can get just the base a little cheaper than the base/handset combo) and recycling your old one properly is the way to go if you want to get your base up anytime soon. Once you get a base, you will register your handsets to it, and reset your answering machine greetings, etc. If you have stored settings in your handsets such as the dialing directory, those will still be there. Just google "cordless telephone repair" and the first couple non sponsored links carry the base only. Good Luck
