Question about LG M2362D 23 in. LCD TV
Hello guys, I have a LG flatron Tv LG m2362dp and an ASDA remote Urc220-D4f, & need help setting up the remote for this device, could please help and advise on how to do this.. many Thanks..
Hello guys, I have a LG flatron Tv LG m2362dp and an ASDA remote Urc220-D4f, & need help setting up the remote for this device, I would be great if someone could please help and advise on how to do this.. many Thanks..
Posted by Azaam Mukthar on
John Mabry
    Sergeant:
  • 273 Answers
The remote instructions show codes to use to set-up the remote. There is an extensive number of these codes and usually indexed according to TV's identity. It is easily done with that list provided by the remote manufacturer. Check their website, perhaps there is a PDF of the user guide with the codes.
Posted on Jun 22, 2016
1helpful
Need code for asda remote model #URC20-D4F
asdas remote is generic remote search generic remote controls in search engine and look at the pictures to find your remote, and click on the site to that remote that looks like yours, you should find the remote codes, i would like to help you but the part number applies to over 50 remotes generic codes id the code company use to program the remotes as they are intur usable on most brands that are not the same tv or brand. hope this helps.
I have an Asda remote control URC20-D4F but there's no codes I can find to setup for my LG flatron1080p TV, how do iake it work , please help.. thankyou guys .
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
I need code for universal asda control for a onn tv
http://electro-medical.blogspot.com/
I need code for asda simple remote control for use on onn tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
No sound on my '03 lg plasma flatron tv., model : DU-50pz60
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Using the guide button on the remote i can only select channel7 programs, but no others. Have tried auto tune but still can only select channel7 programs
Hello, I need a few more details to be successful and focus on the problem, I understand you tried the options for manual and automatic scanning. If so did you see during operation the scanning movement on the screen? If so, have you seen the stations in the background while scanning, and the phenomenon was that they did not stop on the station you selected?
30helpful
My LG flatron golden eye tv got Child Locked -
dear sir,
my tv had gone child lock problem & one chenal show the tv. please slove this problem. because remote has been not working.
LG M2362D 23 in. LCD TV Logo
Ekse
