Question about Stihl Saws
SOURCE: how do i replace the pull cord on my stihl cut off saw
it is gonna take some time,take all screws off housing,pull casing off,be careful with the rewind spring and be sure you have spring wound-up for re-install.
Posted on Apr 24, 2009
SOURCE: Fuel bubble cut on Stihl trimmer. ,how to start
yes you can temporary fix with puting some mastic sealer over the bubble and leave for a few hours.
Posted on Jul 24, 2009
SOURCE: I have a Stihl saw. It does not cut like it
Have you tried it with a different bar? I suspect you if you rotate the bar it will cut better from the top down and need to be tipped to cut upward. An inspection of you bar will probably reveal a wire edge. My Pioneer started cutting in an arch. I found the upper rear and lower front bar developed a wire edge (I regularly rotate my bar). I used a a file at 45° to the groove, removed just enough metal to see where the file had been returned my 20" bar to proper service. I think something similar occurred on your bar. HTH
Lou
Posted on Dec 16, 2009
SOURCE: stihl strimmer engine runs but wont cut grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Posted on Apr 07, 2010
SOURCE: 034av stihl chainsaw, after making
I believe you have a clogged or pinched fuel line or a clogged fuel filter.
Posted on Apr 27, 2011
Oct 01, 2015 | Stihl Saws
Dec 10, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Jun 01, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
Mar 18, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
Dec 27, 2010 | Stihl Ts 410 420 Cut Off Saw...
Dec 12, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Nov 07, 2010 | Stihl Ts 410 420 Cut Off Saw...
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
May 08, 2018 | Stihl Saws
808 people viewed this question
