Washing Machines Logo
Question about Electrolux Washing Machines
Hi I have an Electrolux EW Aqualux 1200 in a rented property no manual for the programs would you be able to email me one if available Many thanks rachel
Posted by rachel williams on
Brett Duxbury
  • Electrolux Master
  • 4,352 Answers
Rachel you will find it here if its model number is ew1200
http://www.manualslib.com/download/46075/Electrolux-Ew-1200-I.html
Posted on Jun 21, 2016
1 Related Answer
Anonymous
  • 174 Answers
SOURCE: washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Posted on Jul 20, 2010
1helpful
I have an Electrolux EW Aqualux 1200. Two weeks ago a sock was stuck into filter. I removed it, switch off/on machine a few times, ran machine empty. However since then machine is spinning only if it is...
9 years a good life for Washing Machine, I can't see why you have this problen , since you cleared it by taking sock out of filter, but expensive to get repairer to look at it , as 9 years old , get a new one . Better than spending money on a repair,
1helpful
My wash/dry cycle has finished but I can't open the door. Is there a manual release please?
turn the dial and listen for a click to release the door. no their is no manual release
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
Electrolux aqualux 1200 water leaking from door
have door gasket changed .....01179512835
Electrolux aqualux 1200 ew
hi you need to change your big timer you can have one for 40$ uses
bey good lock
I had a similar problem with a different make recently. After cleaning the filter which didn't seem to have anything in it and rinsing the filters on the in and out pipes I took all the clothes out and ran it empty on two different full programmes and somehow the gremlins disappeared and it works fine now.
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
