LG840 Tracfone 3G Wi-Fi Touchscreen w/ 1400 Min & TripMinutes - Pink - Logo
Joey Simmons Posted on Jun 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to master reset lg touchscreen from dollar general store that doesn;t have a sim card for free
Had too many pattern attempts and would like to master reset it free
Jeff Bird
Level 3:
  • LG Master 1,348 Answers
  • Posted on Jun 22, 2016
Jeff Bird
LG Master
Level 3:
Answers
1348
Questions
0
Helped
363068
Points
4615
Hi this will work with some tablets .hold down power button at the same time hold down the up volume button ..with any luck it might reboot .good luck
T47B Tablet how to unlock screen forgot code
Hi Mate,
  • On the unlock screen, enter your unlock pattern
  • After five attempts you'll be asked to wait for 30 seconds. Tap OK
  • If your phone display goes off, tap the power button and unlock your screen
  • Tap Forgot pattern? If you haven't set up a Google account you won't get this option, instead you'll need to reset your tablet
  • Enter the username and password of your Google account, tap Sign in
  • You'll be asked to create a new screen unlock pattern. If you don't want one, tap Cancel
To reset your tablet:
  1. Turn your tablet off
  2. Hold the volume down key
  3. Turn your tablet on
  4. Using the volume down key, highlight Wipe data/factory reset and press the power key to select
  5. Press the volume up key
  6. The reset is now complete.
Note: Resetting your tablet will clear all the data stored, data that's stored on your SIM is safe.
Cheers!!
Reset zte maxx
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to the 'PERSONAL' heading, then tap Backup & reset.
  4. Tap Factory data reset.
  5. Tap Reset phone.
  6. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  7. Tap Erase everything.
Master reset with hardware keys
If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
    Press the Volume down button to highlight wipe data/factory reset.
  3. Press the Power button to select.
  4. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  5. Press the Power button to select.
  6. Wait as the device resets.
Need to reset. grandson loged
Hard reset, Press the volume up and power button for about 10-15 seconds to reboot. Wipe data/Factory reset.
Unlock my hkc tablet
My daughter locked her self yt? Her hoc tablet too many pattern attempts forgot her Google account we have no WiFi at the moment we do but we can't sign in customer the tablet so t even let her connect the password to WiFi we need help to master reset we try the pinhole nuttiness happens it turns off but back to point a we need help
Too many pattern attempts to unlock my iview 754tpc but my wi-fi was switched off so how do i sign back in
only by putting a sim card with a active data connection in the device then attempt to unlock, you can not remotely turn on wifi very easily, may be a bit more simple if you have debug mode turned on but most people don't-Good Luck.
Lg v909 tablet keeps rebooting
My LG v909 is complaining of 'too many pattern attempts'. Its asking for my gmail login credentials however it has no internet though a data sim card has been inserted. Anytime I insert/remove the sim card the desktop shows for only 5seconds and reboots. Can anybody help me please ?
1helpful
Reset system to factory settings
here is the solution for identity korean tab
all you need is SD card..512 and up..
format SD card in FAT 32
here is the flash files
extract this file and put in sd card
inset the SD card and power on your tablet
PUSH the reset button beside the usb
you will not see it flashing..
wait till astro boy or android boy pop up...
then erase the file at put this file again in SD card
you will see Korean character
do not touch anything..just wait for 5 minutes then it will reboot once more.
done.........your tab is working again.....rolleyes.gifrolleyes.gifbiggrin.gif
To many pattern attemps
Here is the solution for identity korean tab
hang in logo..pattern lock.......
all you need is SD card..512mb and up..
done.........your tab is working again..... :-)
Top LG Tablets & eReaders Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
