Star Micronics TSP600 Thermal Printer Logo
Question about Star Micronics TSP600 Thermal Printer
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
Model number: TSP643 Power light: Solid Error light: Flashing Paper: Reloaded twice, loaded correctly Self-test (Turn off, hold FEED button while turning back on): Attempted twice, machine made a sound but nothing printed Cover is closed correctly. I have also tried turning it off, waiting and turning back on and restarting my computer, just in case.
Posted by Chrissie Bruyninckx on
  • Chrissie Bruyninckx
    Chrissie Bruyninckx Jun 22, 2016
    Had a technician out and looks like the machine is just plain broken. Thanks for the help, but we'll have to replace it! Given it's over 10 years old it's not overly surprising.
Brett Duxbury
  • Star Micronics Master
  • 4,352 Answers
I know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Posted on Jun 21, 2016
I replaced a tsp600 with a new tsp600
There are DIP switch settings in the printer, Check the old one and change the new on to match.
I have a Star TSP600 Thermal Printer which is displaying a red error light.
Are you sure the paper is correctly routed? It will pass a detector. Mis-aligned paper, or defective/damaged detector will present the error.
He printer goes to print but the page comes out blank
Hi
Please load the paper correctly with the side that can be scored by your finger nail pointing downwards.
Contact [email protected] for further help.
Star Support
3helpful
My tsp600 receipt printer will not print and the error light is on.
Dear Oasis Pools,
Please advise if the error light is flashing or solid. Also, perform a self test by turning the printer OFF, hold the feed button down, then turn the printer ON at the same time. A self test should print out. Did this print?
Regards,
Star Customer Support
For further assistance, please contact our Support Team at 800-782-7636 Option 2 for Tech Support or [email protected]
Will not print correct as a network printer
1. Define your Star Micronics Printers device model TSP600
2. Define your operating system to install your Star Micronics Printers device
3. Search Printers driver category
4. Find Star Micronics Printers driver
5. Select Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
6. Download Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
7. Install Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
8. Restart or reboot your computer to finish your driver installation.
Download here:
http://www.opendrivers.com/driver/247183/star-micronics-tsp600-printer-network-setup-utility-ver.-2.0.1-windows-xp-2000-me-98-95-free-download.html
Im using a Star TSP600 printer, it respond to the computer but the paper prints a lot of quetion marks insted of the normal text, what mite be the problem
Make sure the dip switch settings are correct. This is probably a serial interfaced printer and the baud rate or parity is wrong. Do a self test on the printer by holding down the feed button and turning on the printer, release button after the printer starts printing the test page. Now make sure your computer settings match the printer settings exactly.
My star tsp600 has stopped working properly. The auto cutter no longer works and the receipt paper does not advance fully.
You will need to take the printer in for a service. The cutter is Jammed and that causes the fault on the paper feed.
6helpful
Blinking red error button
Blinking light can be caused by a multitude of problems, but in most cases it is caused by the little white switch that you see when you open the printer lid to install paper. Has to be replaced by a printer technician who can get the part from star micronics. Another cause is bad cutter or paper out switch located under lid at the back of printer in which the paper pushes the switch into the side of the printer. None of these problems can be solved by an end user.
3helpful
Paper feeds as if normal but no printing appears on paper
If it is now printing blank and was working before the paper roll change then you need to flip the roll over and print on the other side of the paper. This is assuming you have the correct thermal paper roll.
Top Star Micronics Office Equipment & Supplies Experts
David Shaub
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
