Question about Taylor Digital Cooking Thermometer
The Thermo temp flashes HHH ....and the thermometer keeps beeping...??? What do I do!?
Posted by Lisa Meyer on
  • Taylor Master
  • 18,520 Answers
That means the temp is higher than the unit is able to detect. If it has been exposed to very high heat then it is damaged. It may still have a bad sensor.
Posted on Jun 20, 2016
How can i stop the taylor 1341 digital thermometer from beeping.
remove four screws on back of unit,cut red wire going to round beeping speaker inside lower front faceplate. problem solved it will never beep again but still read temp correctly.
May 19, 2014 | Taylor 1431 Digital Wireless Thermometer
Displays just lines on outside display and has displyed HHH on both displyas , inside temp is fine
HHH means the temp is over the range that was designed. Where did you locate the sending unit?
Mar 11, 2013 | Radio Shack Wireless IndoorOutdoor...
How do I replace the battery in my thermo scan plus ? cna't seem to figure it out Help I need it as my son is ill and the doctor keeps asking for his temp?
Simply press the small recessed button (a small triangle is pointing it ) directly above the battery door with something slender like a ballpoint pen or a toothpick, while pushing the battery door down, away from the thermometer.
Feb 07, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How do i set the thermo sensor 433mhz to my westclox 70034 model
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Oct 11, 2010 | Vacuums
Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
Sep 26, 2009 | Frigidaire Ovens
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
HHH Error Code
Generally, an HHH error code means the machine is sitll too hot from making the previous loaf. Keep the door open for a bit and allow it to cool down.
Dec 25, 2008 | Sunbeam 5891 Bread Maker
Maverick et 72 remote thermometer when it is turned on it reads HHH
If the receiver and/or the transmitter display LLL or HHH instead of the probe temperature,
wait for probe to reach room temperature. If LLL or HHH is still displayed it is likely the
internal probe wire has shorted out either through moisture or heat damage.
-Tha Mp3 Doctor
Nov 27, 2008 | Maverick Wireless Remote Smoker...
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
Preheat beep indicator is inaccurate
It's working ok. These often beep after a preset time. It may be set to beep at 10 minutes. Not always at the temp set. It is usually close enough though.
Nov 19, 2007 | Magic Chef CER3725AA Electric Kitchen...
Taylor Digital Cooking Thermometer Logo
2,739 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
