SOURCE: is jvc kd-g335 blue tooth compatable
If it is a "Ready for BlueTooth" model you will need this adapter JVC KS-BTA20
SOURCE: bluetooth turn on
Hello imback2009,
The JVC KD-G140 does not have a Bluetooth option, either built-in or with an adapter. And as far as I can tell, it doesn't have a "mute" or "phone" wire which would allow installation of a generic bluetooth adapter, such as the Parrot. If you want to connect your cellphone, I'd recommend you look at an upgrade here.
Hope this helps.
Testimonial: "The information was very helpful and Im grateful for the quick response. I still dont understand why there is a bluetooth icon. But, Im satisfied"
SOURCE: how do you use bluetooth on the jvc kd-g230
That model does not have bluetooth installed on it unless you buy an aftermarket bluetooth adapter.
SOURCE: How do I switch the
How do I sinc my iPhone to the cd player or how do I sinc cd player to my phone
SOURCE: How to use jvc kd-hdr20 car stereo. I need to know
To pair a bluetooth device with the radio, turn on the Bluetooth function of the device. Then press the SRC (source) button on the receiver. Select BT Audio or BT Phone, depending on the device you want to pair with the radio. Use the up/down arrows to select New Device and press the down arrow. Select Open and then press the down arrow. Then enter the PIN by using the left/right arrows to select a digit and turning the volume knob until the correct digit is entered. (For some devices, you need to enter a specific PIN. Consult that device's manual.) Press the down arrow to set the PIN. Enter the PIN in the device you are pairing to the receiver (if it doesn't have a required PIN). Wait for the message "Connected" to appear.
To use the device in the future, press SRC and choose the appropriate Bluetooth type. Then use the right/left arrows to select the registered device. Press the down arrow and then use the right/left arrows to select Connect and press the down arrow. (See the manual, link below, for setting the autoconnect or autoanswer.)
To adjust the sound system balance, press and hold Menu to open the menu and then turn the volume knob to Audio. Press the center of the Volume knob. Then navigate to balance and adjust the unit as needed.
The manual for the KD-HDR20 is available from JVC on the product support page: http://support.jvc.com/consumer/product.jsp?archive=true&pathId=54&modelId=MODL028465 . The direct link to the instruction manual is http://resources.jvc.com/Resources/00/01/14/LVT1960-001A.pdf .
I hope this helps.
