Question about Haier Refrigerators
Haier wine cooler model cb112g compressor gets hot but fridg dont cool..whats the problem?
Posted by tom lip on
5 Related Answers
Anonymous
  • 171 Answers
SOURCE: I have a mini fridge
Hi ejb9,
I'm Harvey the Master Plumber.
Your question is: You have a mini fridge at school, a small Haier. Your fridge is getting power and the motor gets very hot but the fridge is not cooling, not even a little... any ideas???
May be low on freon or cloged expantion valve. You're going to need a certified tech to check and repair. Maybe it's time to look at the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
Anonymous
SOURCE: OSTER WINE COOLER
I followed the advice of Ancient Bob and located the heat shrinked fuse as he described. I removed it from the circuit board using a very small tipped soldering iron and repaced it with an inline fuse holder with about 1" leads(Radio Shack or Auto Parts store) and carefully soldered it in place on the circuit board. This makes a fuse replacement a snap if necessary later..I used a 5A 250V fuse as original. It has been running fine for two weeks now, I think the fuse in question blows if the ambient temperature gets too high in the room-a design defect (my opinion). As Ancient Bob said, the total cost was about six dollars icluding 3 extra fuses. Care must be taken when removing the solder, or resoldering the circuit board. It's not complicated but must not be sloppy. After removing the original fuse I drilled out the circuit board fuse holes (they may fill with solder as a byproduct of removing the fuse) with a tiny drill bit to make the installation of the inline fuse neat and easy. Good Luck
Posted on Oct 03, 2008
Anonymous
SOURCE: where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Posted on Jun 05, 2009
Anonymous
  • 205 Answers
SOURCE: our wine fridge doesnt seem to be cooling properly
it may be as simple as the coils needing cleaned you can buy a can of condeser cleaner at your local hardware store.
Posted on Oct 14, 2009
Anonymous
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
Posted on Mar 24, 2010
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
I have a Haier wine cooler BC112C. The compressor will not kick in (but I can hear the relay switch engaging) unless I plug and unplug the unit 4 or 5 times, then the compressor cools to the proper...
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 10, 2011 | Haier BC112G Wine Cooler
My Hair 12 bottle wine cooler quit cooling. what is the main cause?
Possible bad thermostat. Bypass the thermostat wire to run the compressor. If the compressor start, replace the thermostat. On the other hand if the compressor is running, and there is no cooling; there is a leak and all the refrigerant probably escaped. If it is the case, you need to call serviceman and have him evaluate the wine cooler for possible repairs. P.S. The serviceman may charge a fee for evaluating or estimating the cost of repairs.
Dec 29, 2010 | Haier BC112G Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Apr 30, 2010 | Haier HVUE08A Wine Cooler
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine fridge not cooling
It is normal for a compressor to be hot to the touch, but not super hot. clicking noise sounds like the relay located on the compressor terminals is bad. Hope this helps
Jul 27, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
May 03, 2009 | Haier HVFM20ABB Wine Cooler
Refrigerators Logo
76 people viewed this question
Top Haier Refrigerators Experts
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
