Lowe's of Bowie incorrectly installed a toilet which caused damage to our apartment and the unit below us. They fixed the toilet and corrected the damage on the lower apartment, however they did NOT correct the damage in our apartment. Can you help us?
SOURCE: Right speaker has a shorrt
Access screws on headphones are sometimes under the ear padding, or maybe on the opposite side under a sticker or label. Sometimes the wire will have come loose from the internal speaker, or it could be the external cable has been abused enough that the copper strands inside have separated.
SOURCE: Incorrect speedometer reading
the spedo is electronic and works with a sensor located in the tranny case you can see it right by the starter end its the black plastic thing with a single 3/16 allen bolt in it remove it and make sure it is clean no metal shavings(its a magnetic hall effect sensor) if no shavings exist then you have a problem with the spedo and it can only be replaced harley wont repair them
SOURCE: Canon Mp 610 error u052 incorrect print head
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
SOURCE: The type of print head is incorrect, please install the correct print head
patchiepoops,
make sure everything clicks. canon is known for their ''slide and click fittings''
don von gideonberg
SOURCE: incorrect printhead
It just means that the printhead is defective, All of the Canon machines say that when the printhead goes out.
