Question about Konica Minolta Bizhub Press C6000 Copier
Error j3201 konica c 6000
Jammed j3201. i have cleaning all sensor. wen you product 2000A4 probleme
Posted by attie fadel on
Electro Med Services
  • Konica Minolta Master
  • 6,694 Answers
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on Jun 17, 2016
Konica Minolta bizhub 180 printer error Paper Jam *Open 1st SIDE COVER* I have opened it, cleaned it do not see a paper jam. How do I clear the message so I can print?
Check the accurator for the sensor that tell the copier paper is there might be broken or out of alignment
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 20, 2017 | Konica Minolta bizhub 180 All-In-One...
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
C-2813 error code in c-6000 help us
2813...related to cyan.
Excess charge on drum beyond the specified value.
Solutions...1) swap the drps board with yellow or with other color unit and see weather code is changing .if it is changing the drps board is the culprit.
2) clean the HV contacts located behind the processor unit.
3)clean the IDC Sensor unit
4)change developer
5)caronas
Oct 27, 2012 | Konica Minolta Konica Kit For Bizhub Press...
6500 konica minolta biz pro error code 2840
Konica 6500./6501/5500/5501/6000 printer 2840 problem/error
Solution...this problem is due to color correction unit PGC Sensor. While reading the maximum density this problem has occurred. This centre sensor is also called Gamage sensor.
It is situated at the top left side opposite to Image transfer belt unit for reading the patches as well as maximum density.
The problem is due to dust or toner scattering in these 3 sensors.take out the unit thorowly clean all the three sensors including the contact sockets.
Ensure that all the three shutters are opening properly for all the three sensors.
The centre PGC Sensor is covered with two white tabs.please gently remove them and remove the toner by cleaning.there are chances for toner accumulation under these white plastic tabs.
After cleaning all sensors fix it and do auto Gama adjustment.and color registration adjustment.
PGC and other left and right sensors of the color registration/correction unit also gives 45-20error most of the time either due to dust or due to non opening of the shutters
Jun 11, 2012 | Office Equipment & Supplies
My Konica Minolta 2530DL printer has paper jam ,as i tried to remove paper a part of it tornoaway and got stucked in the fuser roller arear. How can i remove the fuser to get the piece of paper out
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Sep 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Printer will not pick up paper and gives a paper jam error at tray 1. There is no paper jam.
change or clean the pickup roller for the first tray, and make sure no small paper stucking on sensor , check the sensor if its on right place or not broken. and u will be fine.
Clean the pickup rollers by alchohol
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 09, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Xerox c118 error
hi its a registration sensor error.. first u try to clean sensor.. again its not working better u replace a new sensor...
Sep 29, 2008 | Xerox CopyCentre C118 Copier
Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
May 23, 2008 | Konica Minolta magicolor 2400 Laser...
Konica 4155 - J16 Paper Jam
First, check if the paper loaded is matched with the copier settings.
If that doesn't solve the problem, carefully check the paper path sensors.
Feb 07, 2008 | Office Equipment & Supplies
Konica Minolta Bizhub Press C6000 Copier Logo
454 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
