Question about Singer Sewing Machines
How to take apart a singer sewhandy 50d to rewire it?
Want to replace the cord, but can't take it apart.
Posted by Dale Young on
Chance Miller
    Sergeant:
  • Singer Expert
  • 455 Answers
These machines are not user serviceable, no parts will be available to the general public.
Please have a trained service technician look at your machine. electrical issues and mechanisms do require service from time to time, especially with heavy use. If you use your machine frequently, have it cleaned and adjusted based on your use levels.
Cheers,
Embroidery Services
San Diego, CA
Posted on Jul 27, 2016
2 Related Answers
Anonymous
  • 111 Answers
SOURCE: I have the Singer Sewhandy Electric sewing machine
I have the needles in stock at $1.50 each. Stepping Stones Quilts, 912-638-7128. Go to a gunsmith for the screw. cv
Posted on Aug 23, 2009
SOURCE: I need the rubber covered
try sewingpartsonline.com
Posted on Jan 18, 2011
Singer sewhandy model 40k
I'm not familiar with that machine, but it appears that you DO have documentation for it, which is a GREAT help, as you've found out. My only suggestion offhand is to make absolutely sure that your needle is ALL THE WAY UP in the needle color; that's a common cause of needles not pickup thread.
Sep 03, 2014 | Singer Sewing Machines
Why singer sewhandy 50 will not sew
It is likely extremely dirty inside. The front of the top part of the unit swings open where the light bulb resides. It is very hot when the light is on, so make sure it\'s OFF when you open it up. Look for any corrosion, dirt, etc. inside. If it\'s spic-and-span, then the problem is in the bobbin inside the door below the needle. Pull out the bobbin, search for debris or string wound around the bobbin spindle (it\'s hard to see sometimes). Clean those parts if you can. Otherwise, take to Singer dealer for repair. These are highly sensitive, precision machines that should run a lifetime or two if kept clean and dry.
Sep 03, 2014 | Sewing Machines
Where can I buy a replacement foot controller and power cord for my singer confidence 7463?
Years ago, my second Singer [760] foot control "went", out of warranty. Singer weren't very good with parts for older models, and the sewing machine guy had to find another foot control and I had to do a lot of rewiring.
Anyway, if you go Online and look for your local Singer stockist, the part number should be there.
Oct 03, 2013 | Singer Confidence 7463 Computerized Sewing...
Singer 50d toy
try a1sewingmachines.com and ask them what bobbin will work and see if they have one.
Jul 11, 2013 | Sewing Machines
What parts to oil on singer model 50d sewing machine
here is a free manual, check and see if this manual is the right one
for the machine and it should have the information about oiling the
machine.
http://www.singerco.com/uploads/download/40_50d.pdf
Dec 29, 2012 | Sewing Machines
Light dims when you sew
the problem is that the cord that was replaced on it is too light for the sewing machine. some companies sell cords that are made with 18awg wire 18awg wire can only deliver enough electricity to run the motor sapping up all of the power from the light as soon as you push the pedal. you need to get a cord made by singer or rewire your cords with 16awg wire... 16awg wire is the standard wire for all vintage singer sewing machines it keeps the light nice and bright...... hope this helps
Aug 06, 2009 | Sewing Machines
Sewing Machines Logo
167 people viewed this question
Top Singer Sewing Machines Experts
Irene Tulloch
Chris Wetmore
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
