Dyson DC35 Handheld Vacuum Logo
T
Toni Elvins Posted on Jun 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a Dyson handheld vacuum DC35 , when I plug the rechargeable battery in to charge the green light is just flashing and does not seem to hold charge
Dyson Solutions Dumfries
Level 2:
New Friend:
  • Expert 102 Answers
  • Posted on Jun 18, 2016
Expert
Level 2:
New Friend:
Answers
102
Questions
Helped
51141
Points
151
This means your battery is flat. When charging the battery if the green light on the charger is on then charge is getting to the battery. If the battery isn't holding a charge then you will need to replace the battery.
1helpful
My Dyson DC35 just stopped .
Question edited for clarity and typos. Please don't call a Dyson a 'Hoover' (registered name of Hoover Inc), James Dyson will be very upset. :>D
Yes you can buy batteries very easily, but you need ascertain that it is the battery, or the charger, or the control board? With a digital multimeter it is very easy to check battery and charger, but you will need Dyson service to diagnose a board issue.
https://www.google.com/search?q=Dyson+DC35+battery
Won't charge, no green light on plug
I plugged in the charger into the wall. I get a green light on the charger but the light on the vacumn doesn't turn on?
Unit will not charge.when plugged in light flashes red then goes off
It appears that the battery has outlived its usefulness. They do go bad after numerous recharge cycles.
1helpful
When I press the trigger the green light comes on but motor does not
Hi Peter, it's Jack at Dyson.
From what you're describing, it does sound as if your DC35 needs to be recharged. When the machine is charging, the LED on the charger will illuminate, but the LED on the machine itself will not. When the LED on the charger goes out, the machine is fully charged - this will take 3.5 hours from depleted.
Please try connecting your DC35 to the charger cord and allowing it at least 3.5 hours to charge until the LED on the charger goes out, then test your machine. If it's still not running at this point, we will need to talk you through some simple diagnostic checks when you have your machine to hand. This will help determine whether there's an issue with the main body, battery or the charger itself.
You can reach our experts by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Hi Perry, it's Jack at Dyson.
If the green light comes on when your DC35's trigger is pulled, but the machine does not run, this would usually signal that the battery has no charge.
The battery should recharge fully from depleted in 3.5 hours. However if your machine has been connected to the charger for at least this long and still won't run, it could mean there's an issue with either the charger or the battery.
We're happy to talk you through some simple diagnostic checks when you have your machine to hand, to help determine which part is at fault. At your earliest opportunity, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Wont run green light flashstrigger problems
Hi there, it's Jack at Dyson.
If your DC35 won't run and displays a flashing green light, our online Support guide should help you diagnose the issue: http://www.dyson.co.uk/support/dc35/dc35-multi-floor/my-machine-is-not-working/my-machine-displays-an-led-light
If you find you need some further help after giving this a try, you can reach our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can confirm if this is covered under our free 2-year parts and labour guarantee.
How do you know when the battery is charge
If your machine's charge has been completely depleted, it will take a maximum of 3.5 hours to recharge again completely. When it's fully charged, the light on the charger will go out. You can either plug the charger cord directly into the machine, or store and recharge the machine in its docking station.
I hope this helps, but if you'd like any further information you're welcome to contact us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
1helpful
I just bought a Dyson DC35 cordless vacuum cleaner, and the charger does not light up, nor does it seem to be charging the vacuum cleaner
Hi Jeff, it's Jack at Dyson.
DC35 should charge completely within 3.5 hours, and when fully charged the light on the charger will go out. If the battery doesn't seem to be taking in any power, we'd appreciate the opportunity to take you through some quick diagnostic checks when you have your machine to hand. If a replacement part is needed, our experts will also be happy to confirm if this is covered under your machine's 2-year warranty.
You can reach the Dyson customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
