Question about Panasonic TCP55GT30 - 55 VIERA 1080p Plasma 3D HDTV, TCP55
My tv has shut off and will not turn on. it sounds like it is being turned on but the screen stays black, and the power red light is constantly blinking. please advise.
Posted by Emily Roveto on
    Top Expert:
  • Panasonic Master
  • 76,416 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jun 16, 2016
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Get a black screen when turned on
Same thing happened to me. Unfortuanatley, I had to get a whole new phone because it was a "manufacturer defect"
Jul 05, 2015 | Televison & Video
My Samsung TV won't turn on
Please describe the problem more accurately. Flashing red usually means 'stand-by' state, flashing blue/green - starting up. When (during that) do you have a sound? Are there any 'high voltage' sounds like soft screeching from the screen? Is it LCD or LED?
Mar 02, 2015 | Samsung Televison & Video
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Open Questions:
See all Panasonic TCP55GT30 - 55 VIERA 1080p Plasma 3D Questions
Panasonic TCP55GT30 - 55 VIERA 1080p Plasma 3D HDTV, TCP55 Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
