SOURCE: CHANGING THE RINGTONE
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
SOURCE: change the ring tone of Panasonic KX-T7730
I think it can be done. Just exchange the phone for a 7633 and change out the TA for a TDA-50.
Piece of cake.
Carl
SOURCE: CHANGING THE TIME ON PHONE
I can give you the fast answer and the slow answer. Fast one is to go to the main phone, press PROG and dial **1234. The system should go into programming and you will be looking at system program 000. ENTER. From there, using a combination of the SEL, FWD and CONF keys, you should be able to navigate around the time change, using ENTER or STORE to save it.
The arder way is to grab the manual here http://www.public.carl.airpost.net/TDA/TDA_PTPM_32.pdf and start reading it from page 12 then follow the instructions on page 16.
Keep in mind that TDA programming is usually done from the master phone, or any phone assigned programming status. It may be all or NONE.
Carl
SOURCE: How do i set up new Extention names and numbers
Extensions are named in the 004 programming section of System or Manager programming. You have to have access and a password to get there. Generally, we give everybody access to Manager programming, but your installation may be different. Extension 101, the operator's phone, by default has access, but it may have been changed.
Try page 177 forward with the 004 command on page 183 in the attached manual link. Somewhere, there will be the key to entering letters as you name the extensons.
http://public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Carl
SOURCE: How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
