The unit has power, as the digital clock works and will turn off when switched at the fuse. the thermostat clicks on but no heat, light, fan or indicator light. I assume the element is the most likely culprit but could it be something else like the thermostat?
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
SOURCE: my candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Testimonial: "Thanks looks like it'll cost a fortune!!"
SOURCE: Candy Electric Oven no power in oven/grill at all, only clock
is the timer set, most ovens wont work if the timer is not set
SOURCE: The main oven, fan assisted, blew the fan element.
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
SOURCE: My Omega oven has stopped
The oven has a thermal trip switch behind the back wall of the oven and is under the back cover. It is attached to the back outside wall of the oven towards the top. Some thermal switches can be reset but most usually have to be changed. If you are handy you may be able to open the switch and click the little disc backwards and reassemble the switch. Make sure to refit the disc the right way around. Ensure that the power to the oven is off or the plug is pulled out before attempting to remove the back cover.
Testimonial: "Prompt reply that got me looking in the right direction."
