Question about Ricoh Aficio MP3350
How to fix error sc230
Gives error sc230 when swicthing on or when i want to make a copy
Posted by rovesai charles... on
  • Angie Samaniego-benedict
    so hi there...is this dan payne's son? just curious.
David Payne
    Top Expert:
  • Ricoh Master
  • 14,162 Answers
Posted on Jun 14, 2016
While listening to my scanner every so often, does not seems to be a specific interval, maybe 3 or 4 seconds usually, I get a silent pause missing conversation. For instance the ambulance dispatcher might...
sounds like you have another channel set for priority and it is scanning back to check that channel. In the manual mode scroll thru channel's until you find one set with a "p" or "pri" on the screen. Hit the priority button and this should resolve the problem.
Sep 09, 2011 | Uniden SC230 Handheld Scanner
Ricoh SP4210N printer -- display keeps indicating an error -- SC230. What is SC230?
1. Connect the cable correctly.
2. Replace the engine control board.
3. Replace the laser scanning unit.
4. Check or replace the cable.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Ricoh Corp Aficio SP4210N BW Laser Print
My old scanner had 20 banks of 10 freq. each, am having trouble understanding the instructions for the SC230. Is there a site or booklet that has the instructions spelled out simplier.? thanks Ed...
Wow, Uniden did their best to make the SC230 manual confusing, didn't they? Here's a link to a much easier to read/use manual that was put together by an SC230 owner who couldn't figure out the factory document. I hope it helps.
http://marksscanners.com/230/230.shtml
Bill B.
Listening in since the 60's
Mar 29, 2011 | Uniden SC230 Handheld Scanner
SYSTEM ERROR E000
Error Coed E000
- Check the connectors of the fixing film unit.
- Need to replace fixing film unit.
- Need to replace Hi Voltage Power Supply Board
- Need to replace DCNT Board.
May 29, 2010 | Office Equipment & Supplies
My Ricoh printer is flashing error code SC230
Looks like the laser unit has quit!
SC230
V-Sync error
Subscan signals are not
asserted.
See SC201.
SC201
Polygon motor error
After the main switch turns
on, the polygon motor is not
phase-locked in several
seconds.
• Incorrect cable connection
• Defective engine control board
Oct 26, 2009 | Ricoh Aficio CL2000N Laser Printer
SC230
this is an error for the transfer belt there is a mark or the belt has been damaged if you open up th efront cover and then look at the brown panel there are two screws either end that nee to be loosened then lift this up next there is two screws on the transfer unit that run diagonally acros the inside of the machine and a third screw on the black unit (duplex) unit this needs to be taken out.. once you have done this there is a green lever in the top left hand side of the transfer unit this needs to be turned to the left to release the roller take the black duplex unit out by sliding it to the fron then the treansfer unit can be pulled gently out.. it is on two runners so it wont fall off you can hten look at the condition of the belt. if it seems ok look on the edges of the belt by gently turning the gear at the back this will feed the belt around.. if it seems ok put it all back in and then put the srews back in close it up and turn on the machine.. wait for it to warm up.. press the yellow clear/cancel button at the top above the number pad then enter 107 then hold down the cnacel/stop button, hold this down till the screen changes.. turn off the machine and bcak on again.. if the reset has worked the machine should run up and be able to copy and print.. if not you will have to do the same proceedure of clear/cancel button routine and once the screen changes select copy sp then go to section 5.mode then scroll down to 810 sc reset. execute and turn off the machine.. wait 5 secs turn on and test again.. if the error code keeps coming back the B.I.C.U Board may be defective and need to be replaced. check the transfer unit condition of the rollers under the plastic clear image belt also.. Good luck A.
Sep 17, 2009 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio MP3350 Logo
820 people viewed this question
Top Ricoh Computers & Internet Experts
Marvin
Marvin
Bernard D'Souza
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
