Question about Philips Vacuums
I'm looking for a spare piece for my HR 2833 Cucina robot. Is the coupler piece. Can anyone help me to find it?
Philips robot
Posted by Fatima Pedro on
Hi. Today I got an I-dog dance from ebay because i like collecting robotic stuff, and he isn't lifting himself. I'd like to know how to repair him. Thanks.
This will be like most actuated toys. Unfortunately there are no spare parts or PDF manuals to service or repair your I-Dog. Have a clean and clear workspace with good lighting, a magnet to keep all of the assembly screws in one place, a small philips head screwdriver and take the body case apart carefully. At this point the legs may come free with their drive servos so go gently. As it's only the rear legs that aren't working you have an idea of where to look for a fault. Look for broken slide pins or cracks in plastic parts, gears that have come loose or stripped or even a broken wire to a drive motor. It might only need a small spot of super glue to fix him up or a small soldered joint. Take pics with your phone while disassembling it so you have a visual guide and even jot down a note or 2 on a writing pad. You might get lucky and manage to return it to 100% working order but you never know with these things...
Sep 07, 2018 | Vacuums
My roomba no longer works on my area rug, it starts backing up continuously once it encounters the rug.
Sorry to read about your problem, I hope this helps you out.
iRobot Roomba Vacuuming Robots and the iRobot Dirt Dog Workshop Robot are equipped with four infrared Cliff Sensors that prevent robots from falling off stairs or ledges. The Cliff Sensors are located along the inside of the bumper. If the Sensors become obstructed by dust or debris, the infrared signal is weakened. Regularly inspect and clean the Sensors. Use compressed air for best cleaning results.
http://homesupport.irobot.com/app/answers/detail/a_id/314/p/5
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Roomba Robotic Floor Bagless Vacuum
I am looking for a cap for my tefal pressing profile steam generator iron model 2880 can you help
Did anyone help you with this? Did you find - I also need one!
Sep 27, 2010 | Vacuums
IRobot 560 does not return back to the charging station as it runs out of battery after 1/2 hr. of cleaning.
You need to put the charging station in an easily accessible area, since the roomba doesn't know where it is if it's in another room. The roomba needs to be quite close to it to be able to detect it. When its battery runs low the roomba will zigzag around at random until it detects the charging station.
Aug 23, 2010 | iRobot Roomba 560 Robotic Vacuum
IRobot Roomba (RED) does not start,
Reset your robot by holding down “Spot” and “Dock” together for 10 seconds. this might help
Jan 10, 2009 | iRobot Roomba 560 Robotic Vacuum
I robot discovery
I have takin several Roombas apart with this problem. Basically the sensors on the bumber are blocked so the roomba thinks it is hitting something. I believe this is a design problem because it is so common. If you could see how the bumbers work, there is an infrared sending unit and an infrared receiving unit (they look like little LED's. when the bumper is pressed, a plastic piece moves between the two infrared led's blocking the transmission. This signals roomba to stop and backup. What happens over time is the sending led thing gets dislodged and moves slightly. The receiving led can't sense the signal so it thinks the bumper is depressed.
Hard to explain, but I have fixed the problem by shimming the led back in place and worst case, I drilled the hole in the plastic piece a little larger. Solved the problem and I have recaimed several roombas that were considered scrap. Irobot should fess up to this known problem and issue a fix for everyone of the defective units.
Jan 16, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
42 people viewed this question
Top Philips Vacuums Experts
Tim Venetis
JonSnell Electronic
JonSnell Electronic
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
