Question about Toshiba Office Equipment & Supplies
How to reset Toshiba Studio 256se Total Counter?
kagimu joseph
    Habit-Forming:
    Scholar:
  • 110 Answers
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Posted on Nov 17, 2017
  • rukmal kumara Apr 05, 2018
    how to e studio 256se counter bckape system.
3 Related Answers
Anonymous
  • 136 Answers
SOURCE: Toshiba e-studio 230 call for service
Call a Service tech
Have him reset yor Counter AFTER he over checks your copier and inspects the Drum,.Transer Unit, and Fuser Unit chances are the previous tech may not have reset the counter
but call for Service to verify those parts are good first ok. I would not want a counter reset to occur if a fuser unit is bad or something. At that low copies it maybe time for corona's to be replaced.
http://www.copierspluswwllc.com
Posted on Sep 13, 2009
didi2005
  • 727 Answers
SOURCE: I have problem Toshiba e-studio 230 when I want to turn on this message will appear ''call for service Total Counter 232844''HOW CAN RESET MAINTENANCE COUNTER IN TOSHIBA E STUDIO 230?
08-252 "0" for clearing the message.
08-251 for setting the value of PM message
Posted on Jul 12, 2012
xeroxtech
arnie
  • 8 Answers
SOURCE: how to reset counter
it is illegal to reset counters
Posted on Apr 22, 2014
How to reset counter in toshiba studio230
You mast have acode at the right of panel
For example c400
Tell us what is the code to help you
Aug 24, 2016 | Toshiba E-studio 230 Copier W/net Print,...
Toshiba e studio 2051c showing F101 call for service 5 ERROR . How to fix it?
DH, Toshiba e studio 2051c showing F101, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Toshiba 256se 101 4 error
Toshiba studio 2051c Troubleshooting Manual
Aug 03, 2016 | Toshiba e-Studio 2051C Multifunction Color...
My Toshiba e studio 2051c showing F101 & call for service error . How to fix it ?
DH, Check/ read through the attached links,instruction and guides, Good luck
Toshiba 256se f 104 reset codes
HDD data error
1 Connector and harness check
2 Check if the connector pins of the HDD are bent.
Perform the bad sector check (08-9072). If the check result
is OK, recover the data in the HDD. If the check result is
failed, replace the HDD.
Aug 30, 2014 | Toshiba E-Studio 256 Digital Copier
How to update firmware toshiba studio 256se
Load the firmware to pendrive/usb storage and plug to the machine
Holding 4+9 and ON the machine to enter firmware update mode
Select the firmware u want to update and press START
Jun 10, 2014 | Toshiba E-Studio 256 Digital Copier
Resetting the counter on a Toshiba e studio 2500c
I reached the total print counter 109219 and want to re set.
Oct 23, 2012 | Toshiba E-studio 2500 cbc939390, Copier,...
How do I find the copy counter function on the E-Studio 600 copier?
If the e-Studio 600 is similar to other Toshiba models (like the e-Studio 452 or e-Studio 3510c) you can view the copy count by simply pressing the User Functions button, and it should be displayed in the lower right corner.
If you don't see it there, select Total Counter while you're in the User Functions screen, then select Print Counter.
Did that help?
Jun 06, 2011 | Toshiba COPIERS E-STUDIO 600 Copier
E-Studio 3511 Color Copier written in the screen call for service total counter 372278, how can i solve this problem?
hello
we have like that message before in our copier also but the only thing i did is shutdown and start again and i reset the counter and it goes fine.
make hard reset remove all the power cable and plug again.
thanks
Mar 15, 2011 | Toshiba E-Studio 3511 Color Copier
1,047 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
jasbo
jasbo
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
