Hi, Its recommended that you should take the ECG on battery backup. Because if you use power line while taking the ECG there is a possibility of interference on the base line. Try to replace the battery before taking ECGs. OK
- Go to the storage program by pressing "Shift" + "Store/retrieve" simultaneously. - using the down arrow, move the cursor to the space where your ECG's are listed and underline the ECG you wish to re-print. - Once the ECG is underlined, press "Shift" + "down arrow" simultaneously. Two little cursors will state that the ECG is selected. - Press "Enter". The cursor will come back on top of the screen, on "Print". - Press "Enter" again. The machine will start to print.
hi,
When the at2 is in auto mode, first of all it check the leads are properly connected or not.Then it will acquire the ECG and store the same in its memory then only it starts printing. that's why it takes that much time to give a printout. When its starts printing you can remove the connections from the patient because it have alreadymemorized the ECG.
If interpretation is in on position it will compare the acquired ecg with the standards in its memory (allready programed by the manufacturer). and will give a detailed report with ecg.
ok
What do youmean by not recording ? Is it actually getting the pressure but not recording on paper ? If it is not getting a pressure at all , does it give an error on-screen ? (time-out etc. ) These NIBP units use a pump and there may be a leak somewhere in the line from pump to cuff . If you have another unit or any Mindray unit with NIBP , you can troubleshoot using another NIBP line . Unplug the exisiting and try another line . If not verify the cuff does not have a leak and you can run a leak test withing the unit itself . If you do not have a manual , you can get one online from Mindray or other sources to describe in detail how to run the leak test .
hi, ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable. ok
You can press delete and restart the machine. Sometimes you may have to hit the machine a couple of times. I have even kicked and it worked. All the best
It means there is electronic noise coming from your electrical outlet. You can test to be sure by trying the unit unplugged from the wall. If it does not give the same error then it is definitely you power outlet.
