Question about Zebco Sport & Outdoor - Others
Zebco 11TL Disassemble to repair drag
Posted by wayne whitney on
1 Related Answer
ray gallant
  • 68551 Answers
SOURCE: Zebco one classic feather touch fishing reel:
What about it . we can not guess
Posted on Sep 13, 2017
I plug iron red light stays lit but sole plate dont get hot
The connection to the resistance might be burned out. disassemble carully, might need soldering.
If you disassemble and don't have experience repairing an iron, take photos for each step. See some videos about iron repairing
Iron Disassembly Process
Iron Repair No Power or Short in cord wire Rowenta Master
How to repair broken iron
Iron Repairing sajid salman flv
Oct 26, 2015 | Irons
I have a 2001 polaris magnum 325 4x4 the starter solenoid relay and starter are smoking when I hit the start button. What could be causing this?
Water in your starter, or a dragging hi amp draw starter. Pull stater disassemble and do a failure analysis.
Feb 07, 2015 | Motorcycles
How do i dismantle the rear bait runner drag on a Shimano DL2500 FA reel?
SHIMANOBaitrunner DL Specifications SpinningReels Shimano Fishing NZ
here is a link to a Shimano page with a PDF file link to a schematic for your reel.
This should give you the info you need to disassemble your reel.
if you feel you would rather have an author is repair shop do the work for you follow this link. Home
Oct 14, 2014 | Fishing
Overheating brake pad or rotor
The pads are dragging because they are not retracting enough. You need to pull the whole caliper off and disassemble. Make sure that there are no burrs in the piston cylinder and the piston is not installed crooked.
May 01, 2013 | 2004 GMC Envoy
Brand new taotao 50 scooter....every complete rotation of the front wheel at slow speeds makes a recurring squeak...sounds like disc continuallt touchnig pads at some point in wheel rotation...could it be...
Make sure it isn't a cable acutated disk brake. If it is, it is possible to adjust some slack into it. If the brake is indeed hydraulic, you wont be able to adjust it. A lack of brake fluid wouldn't cause the brake to drag. You could check for return springs and make sure the pads are seated into the caliper correctly. You could even disassemble the brake and use brake grease on the sliding parts. If the drag is very slight, I wouldn't worry about it; the drag will disappear within the first few miles especially if you use the brakes.
Jun 27, 2011 | 2005 MBK Skyliner 125
How do I disassemble a Brother sewing machine? I have it almost open but one part, below where you wind the bobbin, will not come apart. Part of a screw that holds a piece in place fell out while trying...
Disassemble your home sewing machine for routine maintenance Many sewing machine repairs can be made at home, and most repairs can be completely avoided through routine sewing machine maintenance. This tutorial shows you how to carefully disassemble your machine to give it a round of maintenance. You will need a screwdriver - make sure not to lose any of the screws! How to Disassemble your home sewing machine for routine maintenance
Oct 11, 2017 | Brother Sewing Machines
The rollers on the vaccum seemed to be dragging and making a clucking noise when you push forward.
Try to disassemble the rollers, or at the very least inspect, and make sure nothing is getting lodged between the housing and the rollers.
Aug 20, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Front wheels turning hot after driving 5miles or more.
pads dragging or caliper piston sticking. disassemble and clean.
Aug 26, 2008 | 1984 Dodge Aries
Sport & Outdoor - Others Logo
53 people viewed this question
Top Zebco Sport & Outdoor - Others Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Zebco Sport and Outdoor - Other Expert? Answer questions, earn points and help others
