Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Digital control reset
The digital control reset panel won't reset
Posted by tony on
Richard Long
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
I have the 60LN5400-UA I spoke with someone the other day and they suggested to order a power board. I am confused I have no red stand by light but I can see the lights through the back panel.
If the power indicator LED at its front panel is ON, then the power supply regulator section circuit board is OK. The fault should be with its digital main board itself. After power is switched ON, the poser regulator board supplies different voltages to different stage circuits inside. These voltages are controlled by the main system control IC, at its main digital board. Now it do not work, and why you can't power ON the set, either by remote control, or with the front panel control.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 01, 2016 | Televison & Video
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Dryer won't turn on - digital panel is on
Check the fuse. It is mounted on the right hand side of the control panel:
This fuse trips when that element gets too hot. Look for air restriction or a bad blower wheel.
Older dryer from monkeywards is like yours inside:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 15, 2012 | Crosley CDE6000 Electric Dryer
How to reset password
If you can tell us what the os do you use, I can help you reset windows password much better.
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Reset .
Resource: http://www.windowspasswordreset.net
Jul 18, 2012 | GE Security Kalatel TVR3008500 TruVision...
Need four digit code to unlock GE model 25GT240
Hello
To unlock GE TV, you must have its original remote control.
Most GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each procedings until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Jun 09, 2011 | Televison & Video
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
255 people viewed this question
Top LG Refrigerators Experts
Michael Thomas
Michael Thomas
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
