Televison & Video Logo
S
Sellathurai Mahesan Posted on Jun 13, 2016
How do I receive FTA channels on Coship 6750 sundirect receiver?
Its a package receiver but I want to set up this as an FTA receiver by changing the settings but there is no advance installation menu.
1 Related Answer
Anonymous
  • Posted on Aug 09, 2010
SOURCE: I want to convert my coship satellite receiver
CDVB5110D
2answers
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
Activation of keys on an FTAS receivers
Your query > "Instructions on how to install new keys and activate an FTA receiver using a 2GB Cruzer Micro Flash Drive with 3 smarth technology"
Generic responses:
1. depending on your FTA receiver (brand/model/version) (BlackBird, MultiStar, UltraStar, Pansat, Digiwave, Viewsat, Coolsat, Fortec, Ariza, Twinhan... or even clones) you would need to download the appropriate firmware/satellite keys using your PC & Internet connection;
2. links to firmware/satellite keys maybe available from your FTA receiver manufacturer's website or forums such as HashHU FTA
3. in your PC, unzip the downloaded firmware/satellite keys to a temporary folder;
If you are using a stand-alone hardware FTA box:
a. plug in your 2GB Cruzer Micro Flash Drive to one of your PC's USB port;
b. copy/paste the unzipped files in the root directory of the Flash Drive. Verify that you have the .bin or .pmg of whatever your FTA box is using;
c. remove flash drive from PC's USB port and insert into the USB port of the FTA receiver;
d. on the FTA box, using your remote, go to Menu, Settings or Sytem Information, keys, firmware or receiver Upgrade, select USB, select Flash, Save, Activate or Upgrade;
e. wait until the FTA box has uploaded to itself the new firmware/satellite keys;
f. reboot (power on/off).
If you are using PC-based FTA satellite receiver:
i. run your FTA receiver program;
ii. select for Tools/Options/Upgrade or Update;
iii. browse/direct to search in your temporary folder where downloaded files were unzipped;
iv. once found, click OK/Update/Upgrade;
v. in some brand/model/version, there is an auto upgrade/update feature which will download appropriate firmware/satellite keys if you are online.
Hope that the this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
2answers
How can i use cdvb 5668 to view free to air channels
how to ears previous FTA channel & edit new Give detailed step-by-step instructions
2helpful
2answers
When will sundirect service will resume
You'll have to give them a ring.
Click on the link below for your area and number
http://www.sundirect.in/helpline.htm
Regards.
25helpful
2answers
How to unlock coship cdvb5110d receiver?
i have CDVB11OD coshib receiver when i try to install fta channel that time message is dislpya "insert card" how to solve this problem
5helpful
4answers
Forgot password for my Coship CDVB2000E
there are 2 pass first one is 1234 nd second 9949, te second one is or more inoortant changes kind regards http:www.radiocristiaa.co.uk
1helpful
3answers
Re-programming for Optus D2 satellite
what brand of set top box do you have?
Top Coship Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Coship Televison and Video Expert? Answer questions, earn points and help others
